  3. Warnings during import verilog in Encounter
  • Subscribers 91
  • Views 17263
Ankit01
Ankit01 over 10 years ago
Hello all,
I am new to this forum. I am currently working on the digital design. I am using EDI platform for place and route of the digital circuit. I am using FSC0H_D standard cell library ( UMC 130nm Logic FSG process ). I have got the synthesized verilog code of 4-bit Counter. I then opened Encounter went to File and the Import Design. There I added the above verilog file. I then clicked on LEF Files and added following files (I followed the sequence given in the UMC130 Place and Route Doc)
header6m0t_V55.lef
fsc0h_d_generic_core.lef
FSC0H_D_GENERIC_CORE_ANT_V55.6m0t.lef
In Power nets : VCC
Ground nets : GND
Then OK
This is the log file output :
Checking out Encounter license ...
edsxl CHECKED OUT: "Encounter_Digital_Impl_Sys_XL"
Encounter_Digital_Impl_Sys_XL 14.2 license checkout succeeded.
You can run 2 CPU jobs with the base license that is currently checked out.
If required, use the setMultiCpuUsage command to enable multi-CPU processing.
* Copyright (c) Cadence Design Systems, Inc. 1996 - 2014. *
* All rights reserved. *
* This program contains confidential and trade secret information *
* of Cadence Design Systems, Inc. and is protected by copyright *
* law and international treaties. Any reproduction, use, *
* distribution or disclosure of this program or any portion of it,*
* or any attempt to obtain a human-readable version of this *
* program, without the express, prior written consent of *
* Cadence Design Systems, Inc., is strictly prohibited. *
* Cadence Design Systems, Inc. *
* 2655 Seely Avenue *
* San Jose, CA 95134, USA *
@(#)CDS: Encounter v14.20-p004_1 (64bit) 11/05/2014 14:06 (Linux 2.6.18-194.el5)
@(#)CDS: NanoRoute v14.20-p014 NR141101-0648/14_20-UB (database version 2.30, 246.6.1) {superthreading v1.24}
@(#)CDS: CeltIC v14.20-p001_1 (64bit) 10/15/2014 03:59:12 (Linux 2.6.18-194.el5)
@(#)CDS: AAE 14.20-p007 (64bit) 11/05/2014 (Linux 2.6.18-194.el5)
@(#)CDS: CTE 14.20-p003_1 (64bit) Oct 27 2014 04:09:59 (Linux 2.6.18-194.el5)
@(#)CDS: CPE v14.20-p003
@(#)CDS: IQRC/TQRC 14.1.2-s148 (64bit) Mon Sep 29 16:54:36 PDT 2014 (Linux 2.6.18-194.el5)
@(#)CDS: OA 22.50-p007 Tue Sep 30 00:05:09 2014
@(#)CDS: SGN 10.10-p124 (19-Aug-2014) (64 bit executable)
@(#)CDS: RCDB 11.5
--- Starting "Encounter v14.20-p004_1" on Mon Jan 19 17:11:54 2015 (mem=98.3M) ---
--- Running on localhost.localdomain (x86_64 w/Linux 2.6.18-274.el5) ---
This version was compiled on Wed Nov 5 14:06:30 PST 2014.
Set DBUPerIGU to 1000.
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
**INFO: MMMC transition support version v31-84
<CMD> set_global _enable_mmmc_by_default_flow $CTE::mmmc_default
<CMD> suppressMessage ENCEXT-2799
<CMD> win
<CMD> set init_gnd_net GND
<CMD> set init_lef_file {../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/header6m0t_V55.lef ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/fsc0h_d_generic_core.lef ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/FSC0H_D_GENERIC_CORE_ANT_V55.6m0t.lef}
<CMD> set init_verilog countersyn.v
<CMD> set init_top_cell counter
<CMD> set init_pwr_net VCC
<CMD> init_design
Loading LEF file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/header6m0t_V55.lef ...
Loading LEF file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/fsc0h_d_generic_core.lef ...
WARNING (LEFPARS-2007): NAMESCASESENSITIVE statement is obsolete in version 5.6 and later.
The LEF parser will ignore this statement.
To avoid this warning in the future, remove this statement from the LEF file with version 5.6 or later. See file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/fsc0h_d_generic_core.lef at line 1.
Set DBUPerIGU to M2 pitch 400.
WARNING (LEFPARS-2001): No VERSION statement found, using the default value 5.8. See file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/fsc0h_d_generic_core.lef at line 41658.
Loading LEF file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/FSC0H_D_GENERIC_CORE_ANT_V55.6m0t.lef ...
**WARN: (ENCLF-119): LAYER 'metal1' has been found in the database. Its content except ANTENNA* data will be ignored.
Review the LEF files specified in the init_lef_file variable and remove redundant definitions.
Type 'man ENCLF-119' for more detail.
**WARN: (ENCLF-119): LAYER 'metal2' has been found in the database. Its content except ANTENNA* data will be ignored.
**WARN: (ENCLF-119): LAYER 'metal3' has been found in the database. Its content except ANTENNA* data will be ignored.
**WARN: (ENCLF-119): LAYER 'metal4' has been found in the database. Its content except ANTENNA* data will be ignored.
**WARN: (ENCLF-119): LAYER 'metal5' has been found in the database. Its content except ANTENNA* data will be ignored.
**WARN: (ENCLF-119): LAYER 'metal6' has been found in the database. Its content except ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2B1CHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
Type 'man ENCLF-58' for more detail.
**WARN: (ENCLF-58): MACRO 'AN2B1EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2B1HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2B1KHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2CHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN2KHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B1CHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B1EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B1HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B2BHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B2EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3B2HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3CHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN3HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN4B1BHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN4B1EHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (ENCLF-58): MACRO 'AN4B1HHD' has been found in the database. Its content except DENSITY and PIN ANTENNA* data will be ignored.
**WARN: (EMS-63): Message <ENCLF-58> has exceeded the default message display limit of 20.
To avoid this warning, increase the display limit per unique message by
using the set_message -limit <number> command.
The message limit can be removed by using the set_message -no_limit command.
Note that setting a very large number using the set_message -limit command
or removing the message limit using the set_message -no_limit command can
significantly increase the log file size.
To suppress a message, use the set_message -suppress command.
WARNING (LEFPARS-2003): BUSBITCHARS is a required statement on LEF file with version 5.5 and earlier.
Without BUSBITCHARS defined, the LEF file is technically incorrect.
Refer the LEF/DEF 5.5 or earlier Language Referece manual on how to define this statement. See file ../../../SAED_90nm/fsc0h_d/2009Q1v3.0/GENERIC_CORE/BackEnd/lef/FSC0H_D_GENERIC_CORE_ANT_V55.6m0t.lef at line 17890.
WARNING (LEFPARS-2004): DIVIDERCHAR is a required statementon LEF file with version 5.5 and earlier.
Without DIVIDECHAR defined, the LEF file is technically incorrect.
**WARN: (ENCLF-61): 407 duplicated MACRO definitions have been found in the LEF file(s). Their content except DENSITY and PIN ANTENNA* data have been ignored.
Type 'man ENCLF-61' for more detail.
**WARN: (ENCLF-200): Pin 'A' in macro 'ANTHD' has no ANTENNAGATEAREA value defined. The library data is incomplete and some process antenna rules will not be checked correctly.
Type 'man ENCLF-200' for more detail.
viaInitial starts at Mon Jan 19 17:37:25 2015
viaInitial ends at Mon Jan 19 17:37:25 2015
*** Begin netlist parsing (mem=392.6M) ***
Reading netlist ...
Backslashed names will retain backslash and a trailing blank character.
Reading verilog netlist 'countersyn.v'
*** Memory Usage v#1 (Current mem = 393.641M, initial mem = 98.344M) ***
*** End netlist parsing (cpu=0:00:00.0, real=0:00:00.0, mem=393.6M) ***
Set top cell to counter.
*** End library_loading (cpu=0.00min, mem=0.0M, fe_cpu=0.15min, fe_real=25.67min, fe_mem=393.6M) ***
Starting recursive module instantiation check.
No recursion found.
Building hierarchical netlist for Cell counter ...
*** Netlist is unique.
** info: there are 424 modules.
** info: there are 20 stdCell insts.
*** Memory Usage v#1 (Current mem = 400.391M, initial mem = 98.344M) ***
**WARN: (ENCFP-3961): The techSite 'iocore_d' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
Type 'man ENCFP-3961' for more detail.
**WARN: (ENCFP-3961): The techSite 'iocore_c' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'corner_ab' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'corner_b' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'corner_a' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_o' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_n' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_k' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_bs' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_as' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_b' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'iocore_a' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'corega_3200' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'core_2800' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
**WARN: (ENCFP-3961): The techSite 'core_3200' has no related cells in LEF library. Cannot make calculations for this site type unless cell models of this type exist in the LEF library. If the SITE is not used by the library you can ignore this warning or remove the SITE definition from the LEF to avoid this message.
Set Default Net Delay as 1000 ps.
Set Default Net Load as 0.5 pF.
Set Input Pin Transition Delay as 0.1 ps.
**WARN: (ENCSYT-7328): The design has been initialized in physical-only mode because the init_mmmc_file global variable was not defined. Timing analysis will not be possible within this session. You can only use commands that do not depend on timing data. If you need to use timing, you need to restart with an init_mmmc_file to define the timing setup, or you can save this design and use restore_design -mmmc_file <viewDef.tcl> to add the timing setup information.
*** Summary of all messages that are not suppressed in this session:
Severity ID Count Summary
WARNING ENCLF-58 407 MACRO '%s' has been found in the databas...
WARNING ENCLF-61 1 %d duplicated MACRO definitions have bee...
WARNING ENCLF-200 1 Pin '%s' in macro '%s' has no ANTENNAGAT...
WARNING ENCLF-119 6 LAYER '%s' has been found in the databas...
WARNING ENCFP-3961 15 The techSite '%s' has no related cells i...
WARNING ENCSYT-7328 1 The design has been initialized in physi...
*** Message Summary: 431 warning(s), 0 error(s)
Is any of these warnings need to be checked or Can I ignore them and go ahead for Place and Route ?
Plz Help
Ankit
  • Kari
    Kari over 10 years ago
    You can *probably* ignore the LEF warnings, although I would fix as many as possible for a clean session and to make sure we're not missing any real problems. Post back if you need help with these.
    The MMMC issue, however, definitely needs to be fixed before you continue.  Please see the User Guide for more information on setting up the MMMC. Place and route are timing-aware and therefore need the analysis view information, even if you only have one view.
