  3. Test bench specific power estimation using Cadence Encounter...
  • Subscribers 94
  • Views 15351
Test bench specific power estimation using Cadence Encounter tool
envyh
envyh over 11 years ago
I have written a verilog code for a circuit (test.v) and a testbench (testd_tb.v).I use these commands for generating the power using cadence encounter RTL compiler. I have made 3 folders. Work,RTL(where all .v files are stored), Library(which has slow_normal.lib). In the work folder i type these commands :
  1. rc -gui(to invoke the encounter tool)
  2. set_attribute lib_search_path ../library
  3. set_attribute hdl_search_path ../rtl
  4. set attribute library slow_normal.lib
  5. read {testd.v}
  6. elaborate
  7. synthesize -to_mapped
  8. report power
The above commands help me to generate the power for the design but i am unable to get test bench specific power output.Kindly do suggest me the changes that can be made in this code.
  • MStarilov
    MStarilov over 11 years ago
    First of all, testbench is not synthesable and you don't need to read it in synthesis tool.
    What you actually need is TCF (or VCD) file(s) from simulator.
    Please refer to RTL Compiler documentation about TCF generation and power estimation based on TCF.
    Hope this helps,
    Mikhail.
