  3. PG ports in the original VHDL IP duplicated by VSS_0, V...
  • Subscribers 94
  • Views 14234
PG ports in the original VHDL IP duplicated by VSS_0, VDD_0
Yemelya
Yemelya over 11 years ago
When running Encounter PnR on VHDL design, which includes declaration and hierarchical connections of the PG ports VSS and VDD, it creates an extra set of ports VSS_0 and VDD_0 in addition to original ones.
I understand that these VSS and VDD from the RTL considered as logical and not physical, but since it is an IP I cannot remove it.
What is proper way to avoid the creation of these VSS_0 and VDD_0, without modifying the RTL?
Thanks and regards,
Boris
