  3. Custom block in core area -- power routing
  • Subscribers 94
  • Views 2841
Steven Mikes
Steven Mikes over 11 years ago
I have a custom LEF that I am trying to integrate into the standard cell core area. My macro lines up with the power tracks on the top/bottom and edges, but not internally.
If I define my macro as CLASS CORE, it will place correctly (with the bottom edge on a VSS rail), but when I do sroute the power stripes go all the way through the block, causing shorts.
I tried defining it as CLASS RING as well: In this case if it happens to place correctly (bottom edge on VSS rail) everything works great, sroute brings the power stripes to the edge of the block and stops there. The problem is that the other half the time it will place the block with the lower edge on a VDD rail instead, making it so that none of the power stripes line up.
Is there a way to get it to both place correctly and respect the blockage inside the macro?
Thanks!
Steve
  • Kari
    Kari over 11 years ago
    Macros should be CLASS BLOCK. You may have to hand-place it though. Or, you can leave it CLASS CORE for placement, then change it to CLASS BLOCK after that and reload the design.
  • Steven Mikes
    That sounds like a solution, what are you commands to save/reload with a different LEF?
  • Kari
    You can't really reload just the block LEF. Best way is to leave it CLASS BLOCK the whole time. But if you want to do the other flow I mentioned, edit the block lef to CLASS CORE. Load your design, do the placement, then save the design and close EDI. Then edit the LEF to be CLASS BLOCK and restart EDI and load the design.
