  3. CCS models usage in EDI
  • Subscribers 94
  • Views 15184
chris06
chris06 over 11 years ago
Hello all,
Up to I was using standard NLDM lib models.
I use now CCS models in EDI.
Are there special settings to be done to force EDI to use the new CCS data present in the .lib?
Is there a command that I could use to ensure that EDI uses the CCS data and not the default ones?
Thanks in advance for your help.
Best regards
Chris
  • chris06
    My question was maybe unclear. I was wondering if there are special settings required or a special timing analyser to be used in EDI when using CCS models?
    Thanks for your help
    Best regards
    Chris
  • chris06
    I cant' find any information in the doc about that subject. Is there someone having a clue?
    Best Regards
    Chris
