  3. encounter SEGV internal error (with optDesign -postRoute...
  • Subscribers 95
  • Views 2231
encounter SEGV internal error (with optDesign -postRoute)
MadapusiSriniv
MadapusiSriniv over 11 years ago
Hello *,
I am trying to debug an encounter SEGV internal error - termination issue with optDesign -postRoute (using the post Route engine-works fine with other engines)  I have attached part of the log at the end of this message.
I am not sure what is going wrong, this placed design works fine with other Tech files -when i load a different tech file into the saveDesign image and perform optDesign postRoute, and extract timing.
So I am concluding that it has something to do with the ICT/TECH file of the buggy run which might be triggering this issue . Please do advice me how to proceed with this.
LOGFILE:
Extraction called for design 'des' of instances=36916 and nets=38779 using extraction engine 'postRoute' at effort level 'high' .
**WARN: (ENCEXT-3530):  Use of command 'setDesignMode -process <process_node>' prior to extraction is recommended for maximum accuracy and optimal automatic threshold setting.
Integrated QRC (IQRC) Extraction called for design 'des'.
No IQRC parasitic data in encounter. Going for fullchip extraction.
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(syStackTrace+0x145)[0xf3b11fd]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0x8f118d7]
[0xf7732410]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_ZN11Cce_Session10InitializeEv+0x55d)[0x1110a79d]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z16qxCCEGetHaloSizePcS_iPd+0x15c)[0xbc7ae9c]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0xbc5ae84]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0xbc5d93f]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0xbc5f7bb]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z14dcRCExtractionPc+0x551)[0xbdad891]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z17peRCExtractionCmdPvP10Tcl_InterpiPPc+0x770)[0xbcd9540]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_ZN10tcmBaseCmd7executeEP10Tcl_InterpiPPc+0xfd)[0x103ce78d]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_ZN6tcmMgr9cmdParserEPvP10Tcl_InterpiPPc+0xae)[0x103c75ae]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(TclInvokeStringCommand+0x4f)[0x10a71e2f]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(TclEvalObjvInternal+0x126)[0x10a72e46]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0x10a992ee]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(TclCompEvalObj+0xa3)[0x10a98853]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_EvalObjEx+0x206)[0x10a74176]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_RecordAndEvalObj+0xb4)[0x10aa6804]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_RecordAndEval+0x4d)[0x10aa66cd]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z17rdaEditCmdLineEndPc+0x298)[0x8e98598]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z9elEndLinev+0x11b)[0xd2447bb]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z21el_callback_read_charv+0x273)[0xd248b23]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0x10ae2922]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_ServiceEvent+0x99)[0x10ac02e9]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_DoOneEvent+0x136)[0x10ac0686]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_AppInit+0x39c)[0x8e96f5c]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(Tcl_Main+0x1f4)[0x10abb814]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(_Z7fe_mainiPPc+0x393)[0x8e96893]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter(main+0x5f)[0x8e9691f]
/lib/libc.so.6(__libc_start_main+0xe6)[0x194d36]
/tools/cadence/edi101/tools.lnx86/fe/bin/32bit/encounter[0x8e96341]
  • KJ1827
    KJ1827 over 8 years ago
    i am facing this same problem on place stage. please help me out divya if you know any solution.
  • Kari
    Kari over 8 years ago in reply to KJ1827
    If you are getting a stack trace, and don't have any obvious errors earlier in the run that you can fix (check your complete log file first), then you need to file a service request so R&D can take a look.
