  3. 6T Bitcell characterization using Encounter Library Cha...
  • Subscribers 94
  • Views 14578
6T Bitcell characterization using Encounter Library Characterizer
jsaenznoval
jsaenznoval over 11 years ago
Hi everyone.
I'm trying to characterize a 6T sram bit cell using Encounter Library Characterizer but unfortunately I can't generate a verilog of this cell. The alf2veri routing reports the following error:
CELL BITCELL6T:
  now reading
  now converting
[ERROR(alf2veri)] behavior is empty
When I look into the gate files, this cell was sucessfully recognized :
DESIGN ( BITCELL6T );
//       PORT DEFINITION
        INPUT BIT_IO ( BIT_IO );
        INPUT BIT_N_IO ( BIT_N_IO );
        INPUT WORD_LINE_I ( WORD_LINE_I );
        SUPPLY0 GND ( GND );
        SUPPLY1 VDD ( VDD );
        -COMPLEMENTARY ( BIT_IO, BIT_N_IO );
//       INSTANCES
        NOT ( Q, QN );
        IMUX ( QN, WORD_LINE_I, BIT_IO, Q );
END_OF_DESIGN;
Besides the boolean file reports the following logical structure:
BITCELL6T
,       REGISTER([QN],[Q])::=(~(WORD_LINE_I?BIT_IO:[Q]),~(WORD_LINE_I?BIT_IO:[Q]))
The behavior of this cell depends on the load so it is really hard to model it in verilog. However there must be an easy way to do it.
