  3. [Encounter] Error (ENCSYT - 16013) load LEF file failed
  • Subscribers 94
  • Views 2364
nitishks
nitishks over 11 years ago
Hi ,
   I am new to Cadence SoC Encounter. While importing the design I am getting the following error:
   ERROR: (ENCSYT-16013) load LEF file sc12_tech.lef sc12_cmos28lpp_base_rvt.lef failed
   As you can see I am first trying to load the technology file and then the library file, so that should not be an issue.
   Can somebody help me in resolving this issue?
   Thanks !!
  • wally1
    wally1 over 11 years ago
    Hi Nitish, I think you're using loadLefFile. You should use the Design Import form under the File menu instead. If you are new to encounter I recommend going through the Rapid Adoption Kit (RAK) titled "Introduction to EDI System 13.2 & Block Implementation Flow" on Cadence Online Support. Here's the link:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Digital_IC_Design/ApplicationPackages/ICD_RAK_Home.htm
    Brian
