  3. FlipChip PIO Flow: Assignment of Bumps fails, but why?
  • Subscribers 94
  • Views 15219
marten
marten over 11 years ago
Hi there,
when I try to assign signal bumps (EDI 14.12) to my IO pins, I always get this error message:
**WARN: (ENCSP-6014):    I/O pin 'DATA_IN[82]' does not connect to placed Area I/O instance or hard macro and will be ignored for bump assignment. Most likely reason is:
1. The Area I/O instance or hard macro is not placed.
2. I/O pin does not connect to I/O instance or hard macro in Verilog netlist.
**WARN: (ENCSP-6011):    There is no I/O pin to assign.
*** End Bump Assignment (cpu=0:00:00.0, real=0:00:00.0, mem=1135.2M) ***
I checked both reasons:
1.) I checked properties of the IO cells, they all have status "PLACED"
2.) I assigned the IO pins within my vhdl code, thats why all the io cells got found even without loading an IO file. And also in the synthesized netlist, they are there
According to the SoC user guide, I did the following steps:
  • init design
  • load io file, load eco file
  • load floorplan file
  • placePIO
  • ciopCreateBump
  • assignBump
So what am I doing wrong here? Why aren't the bumps got assigned?
  • marten
    Found the error: the used pad cells were not member of lef class "PAD AREAIO". I changed the used cells in my vhdl code, so that now cells of class "PAD AREAIO" get used.
