  3. global net connections for VSS are missing after the sa...
  • Subscribers 92
  • Views 18690
global net connections for VSS are missing after the save
anil chatrathi
anil chatrathi over 10 years ago
Hi All,
I have  design, where FP is done and global net connection rules are created and saved the database.
If I load the database the connections are missing for only for VSS in all std cells  giving the below errors:
**ERROR: (ENCDB-1220): A global net connection(GNC) rule for connecting pin 'VSS' of cell 'AND' to global net 'VSS' was specified.  The connection cannot be made because the ground pin and the power net are not of the same polarity.  Check the imported design and make sure the GNC rule is correctly specified or generated.
I tried reconnecting the global nets but give the same error above.
Please help me if any one face this kind of issue.
Anil
  • Kari
    Kari over 10 years ago
    Make sure that the VSS pin and VSS net are both USE GROUND (not POWER). In the .globals file when loading the design, make sure VSS is listed in the gnd nets variable and not the pwr nets variable.
  • anil chatrathi
    Thanks, kari. Actually these nets ( VDD and VSS) are defined in the input netlist with out giving any atrributes. This is creating the isse.
  • Kari
    It is not typical for VDD/VSS to be in the netlist. EDI probably thinks they are signal nets in this case. VDD/VSS should have direction INOUT and are usually handled with globalNetConnect statements.
  • anil chatrathi
    what is the use of keeping VDD VSS nets in the netlist?  some how removing them in the netlist and using globalNetConnect worked for me. But if I keep the them the same issue exists.
  • Kari
    like I said, they are not normally in the netlist. I would question the source of the netlist, why they are there.
