  3. adding filler cells
  • Subscribers 94
  • Views 16531
adding filler cells
kviswanath
kviswanath over 11 years ago
Hi All,
Which type of filler cells should add in soc encounter,I have fill 1,2,4,8,16,32,64 sized and for well tap and end cap also the same values. Which size should i add ??
How to do sanity checks,In my tutorial it is not mentioned.How to do ?? I know only checkDesign -all
  • Kari
    Kari over 10 years ago
    The typical flow is to provide a list of the fillers from the largest to the smallest. Encounter will use what it needs to fill the gaps, since you will have gaps of varying widths between std cells.
