  3. Using RTL Compiler as SynthesisTool in ETPlanner for MBIST...
  • Subscribers 94
  • Views 14967
Using RTL Compiler as SynthesisTool in ETPlanner for MBIST using Tessent
Mangalji
Mangalji over 11 years ago
I am trying to insert MBIST using Tessent. In that ETPlanner step, I want to use RTL compiler as Synthesis Tool. Is it supported? Following is the syntax of .CADSetup file for MBIST using Tessent.
CADEnvironment{
  LayoutTool: BlastFusion | ICCompiler | TalusAcc | TalusVortex | (Other);
  CreateDirectoryCommand: <mkdir Command>;
  CreateSoftLinkCommand: <ln -s command>;
  DefaultSimulator: Verilog-XL | NC-Verilog | (ModelSim) | VCS;
  SynthesisTool: DCTCL | BlastCreate | TalusDesign;
  Simulator (<simulatorName>) {// Verilog-XL | NC-Verilog | ModelSim | VCS
    CommandOverride (<commandName>): <newCommandName>;
    // It is recommended to use the CommandOverride property
    // instead of the two following properties:
    Command: <commandName>;// verilog | ncverilog | vlog | vcs
    CompileCommand: <compileCommand>;
Here bold text describes SynthesisTools that are supported, in ETPlanner reference manual. Please guide if RTLCompiler can be specified there or not.
