  3. ccopt_design - ERROR ENCCCOPT-1135
  • Subscribers 94
  • Views 3736
Yemelya
Yemelya over 11 years ago
I am getting the following error when running "ccopt_design -cts":
ERROR  ENCCCOPT-1135 - CTS  found neither inverters nor buffers while balancing.
"AutoCTSRootPin * Buffer ..." doesn't really help.
How can the required buffers be defined for the "setCTSMode -engine ccopt"?
Thanks and best regards,
Boris
  • BobD
    BobD over 11 years ago
    It sounds like you're mixing the legacy EDI-CTS clock tree spec file with CCOpt.
    I'd recommend using CCOpt's way of specifying things like buffers instead:
    set_ccopt_property buffer_cells "CKBUFX1 CKBUFX2"
    But if you're really intent on running CCOpt with an EDI-CTS clock tree spec file, check out ccopt_design -ckSpec, which directs CCOpt to use the EDI-CTS clock tree spec file.
    Hope this helps,
    Bob
  • Yemelya
    Bob, thank you so much for the so quick and helpful advise. And it also works! -Boris
