  3. [Voltus] set_pg_library_mode command option -power_pins...
  • Subscribers 94
  • Views 4497
[Voltus] set_pg_library_mode command option -power_pins?
JonathanGu
JonathanGu over 11 years ago
im using voltus for power grid view generation, what does the "-power_pins" option inside the set_pg_library_mode command do exactly?
for example,
set_pg_library_mode \
    -celltype macros  \
    -extraction_tech_file <dir> \
     -power_pins { vdd 1.98 }\ ...
is the voltage value 1.98 here for vdd important? by default, it will be set to 1.2, so i guess it is not important to set it to correct value or when i don't know what value to set it to?
thanks in advance
  • Kari
    Kari over 11 years ago
    it is important to set it to the right value. You should know what your voltage is for the design, or the voltage that will be on those pins.
  • JonathanGu
    if my design has 3 different corners, vdd corresponds to 1.6/1.8/1.98 volt, does that mean i need to also run 3 times power grid view generation every time with power_pins vdd set to those 3 different corner voltage values?
  • Kari
    You need to generate power-grid views for the PVT/corner that you plan to run power analysis in. So for example, if you plan to run your IR-drop analysis in ss_0p81v_125c (just an example, your PVTs seem different), then you would create the power grid views with voltage of 0.81v. If you plan to run EM analysis in ff_0p99v_125c, then you would need a set of power-grid views created with voltage set to 0.99v.
  • Srinath VLSI
    Srinath VLSI over 9 years ago
    Hai,
    Am using Innovous 15.2 version.
    How can i generate Power grid library files. ?
    Can you suggest the input files required for generation ?
    Is it necessary to import design as LEF files .
    How can I get LEF for my macros, VDD, rings as in RAK. ?
    Please help me .
    Srinath B
  • Kari
    Kari over 8 years ago in reply to Srinath VLSI
    See the Power Grid Library Generation chapter in the Voltus User Guide. Commands should work in Innovus.
