  3. Enabling SI aware CTS and Optimization
  • Subscribers 94
  • Views 15808
anil chatrathi
anil chatrathi over 10 years ago
Hi All,
I have timing violations because of cross talk in my design at post route stage. All the violations are purely because of cross talk. I want make sure that this is taken care from CTS, post CTSOPT etc.
Is there any way I can make CCOPT  cross talk aware??
Anil
  • J2mh
    J2mh over 10 years ago
    You can define a non default rule (NDR) with a spacing larger and using this rule for CTS. For it: setCTSMode -routeNonDefaultRule {<your NDR>}
    Also you can define an extra spacing in lef file of technology.
  • anil chatrathi
    Thanks for your reply.
    I have used the same and it is working fine now. I just want to know if my design is a congested where I dont have routing resources to keep NDRs  . Is there any way we can make the tool aware of cross talk before routing?  If possible how accurate will be the trial route based cross talk effects.
    Regards, Anil
  • J2mh
    Double spacing implies routing problems if you do not have enough area.
    For avoiding cross-talk before routing I do not know how to do it without modify the lef file of technology.
    Trial route is not the best methodology for routing.
    Regards.
  • Kari
    Kari over 10 years ago
    you can also shield your clocks, but if you are already having congestion with double-spacing, then shielding will have the same issue.
  • sandy2186
    sandy2186 over 9 years ago
    Hi Kari and All
    Kindly let me know which combination of cells (buffer only/ Inverter only/Combo of both) works better for Clock tree synthesis!
  • Kari
    Kari over 9 years ago
    this link is to an old discussion (refers to CTS vs. CCOpt) but some of the ideas may help you.
    community.cadence.com/.../11020
