  3. How to calculate 'Hold' time in the endpoint report?
  • Subscribers 94
  • Views 1717
yamakazu
yamakazu over 11 years ago
I want to know how to calculate 'Hold' time in the endpoint report to identify what is wrong. Could you give me the formula to calculate this? Is there any commands to list them up?
Path 1: VIOLATED Hold Check with Pin SW_SD_PAT_Gr_SW_SD_PAT1_M_SD_SEL32_FF_DTS_
KffF8_O1_reg_6/CK
Endpoint:   SW_SD_PAT_Gr_SW_SD_PAT1_M_SD_SEL32_FF_DTS_KffF8_O1_reg_6/D (v)
checked with  leading edge of 'CLK400M'
Beginpoint: SW_SB_RAM_M_U7076/A                                        (^)
triggered by  leading edge of 'CLK400M'
Path Groups: {reg2reg}
Analysis View: func_fhhb_sigrcmindp_erminus
Other End Arrival Time        208.536
+ Hold                        10787.407    <<=======  what is the formula to calculate this?
+ Phase Shift                   0.000
- CPPR Adjustment               9.873
- AOCV Adjustment               3.200
= Required Time               10982.870
  Arrival Time                402.334
  Slack Time                  -10580.536
  • J2mh
    J2mh over 11 years ago
    That value is extracted from timing library. I think that value is very large because it is out of range so the tool has extrapolated to that value. Hence, there is a problem with the timing library or the design.
    Regards.
