  3. Streaming out GDSII from Encounter (EDI) - gds doesn't include...
  • Subscribers 92
  • Views 2180
Streaming out GDSII from Encounter (EDI) - gds doesn't include standard cells
MadapusiSriniv
MadapusiSriniv over 10 years ago
Hello
I am trying to stream out a GDS file from Encounter EDI, but I notice that the GDS file does not include the standard cells.
I only have a library file and LEF and tech files. I don't have access to the GDS files for the standard cells.
Can someone please help me? I saw A similar post but it did not help me much.
Thank you.
  • MadapusiSriniv
    This is the command I use to output the gdsii : streamOut di.gds -libname libname -outputMacros -uniquifyCellNames -mode ALL
  • Kari
    Kari over 10 years ago
    If you want the GDS of the std cells to be included, you have to provide the std cell gds through the -merge option. If you don't have access to the GDS files for the std cells, then there is no way you can include them. You could have the stream include LEF-based placeholders with the -outputMacros option, but I'm not sure if that's your intent.
  • MadapusiSriniv
    This is what I wanted Kari, thanks for your response. I just included libName and OutputMacros it works. Will post if any further questions. Thanks!
  • J2mh
    J2mh over 10 years ago
    You must specify the -merge parameter if you specify the parameter -uniquifyCellNames.
    For other side, It is recommended to include the gds map file.
    Regards.
