  3. Placement Density
  • Subscribers 92
  • Views 16189
Placement Density
DimitriC
DimitriC over 10 years ago
Good morning everybody,
I would like to ask a question about the placement desnity and the effective utilization of a digital block designed using standard cells.
During the floorplan I set the core occupation at 0.75 (75%) , after the placement the design experiences few timing violations and the density increases to 80.398%. After the optimization all the timing violations are fixed and the design density increases to 80.709%.
Then I implementend the clock tree synthesis, the post CTS optimization, the routing and the post routing optimization. After the last step I got a density of 82.225% and no timing violations. Also the geometry and the connectivity are ok.
At this point I added the filler cells and the density increases to 107%, the summary report stays that:
Floorplan/Placement Information
Total area of Standard cells: 18031.356 um^2
Total area of Standard cells(Subtracting Physical Cells): 13837.874 um^2
Total area of Macros: 0.000 um^2
Total area of Blockages: 0.000 um^2
Total area of Pad cells: 0.000 um^2
Total area of Core: 18040.896 um^2
Total area of Chip: 18642.537 um^2
Effective Utilization: 1.0714e+00
My question is, does the density above 100% a problem? Why the density increase so much after the filler insertion?
Thank you.
