  3. Import DEF to Encounter
  • Subscribers 93
  • Views 4233
FormerMember
FormerMember over 11 years ago
hi everyone,
this is my current situation. I need to do pnr but the .lib files are not available. So I try import DEF file, which is export from Virtuoso, to  Encounter but I've faced some problems like these:
_  when I imported the DEF file to Encounter, these kind of warning occur and the Encounter layout contains almost nothing
 **WARN: (ENCDF-200): Instance I383 is not found in db and ignored.
If this is a physical-only instance, it should have '+ SOURCE DIST' attribute.
_ So I  exported DEF with flattened layout, but there is nothing in DEF this time.
I've searched a lot but still can't find the answer.
I'm new with Encounter so please teach me a lot.
Thank you in advance.
  • Kari
    Kari over 10 years ago
    DEF is not a substitute for .lib. They contain different kinds of information. You need a design netlist, usually verilog, to start. A DEF might contain physical information like placements or power grid. The .lib is the timing information for the cells.
  • FormerMember
    FormerMember over 10 years ago
    thank you for your comment Kari. I actually gave up on that after trying for a while. btw, lib and verilog was delayed release that time so I tried to used another way.
