  3. Question about LEF files
  • Subscribers 95
  • Views 16527
Medya
Medya over 10 years ago
Hi all,
I'm going to implement a simple filter logic and I have two main questions in the following.
First,  When I use the RCP flow there are some warnings associated with the provided LEF files from a foundry related to TECH(Process) definition section. It says that there are missing wire parameters such as CPERSQ ( capacitance per square ) and  RPERSQ (resistance per square) in Layers definitions. Which seems may produce some issues in accurate estimation of RC values during RC extraction. (see the picture). As my design is really high speed I'm concerned about it.  Is there any way to sort them?
Second, could we extract reliable lef files for a provided standard cell technology with any tools and use it instead? (both in front end and back-end design?)
Best regards,
Medya
  • fitz
    fitz over 10 years ago
    The technology lef file parasitic fields are too simplistic for the smaller nodes and have been superseded by separate more detailed parasitic file. Capacitance Table was the first evolution and QRC tech file the second and preferred parasitic file format.
    One of these parasitic files should be in your vendors library deliverables.
    Shawn
