  3. MergeLef
  • Subscribers 94
  • Views 15386
MergeLef
Chith
Chith over 10 years ago
Tool: Encounter 14.2
The design kit has 3 LEF files for the following.
  • Header file (Metal & via information)
  • Core cells
  • Antenna Information for metals & core cells.
During place & route, I add these files in the order given above.
When I tried to create a PG library for Rail Analysis, I got the following warning.
** WARN: (VOLTUS_LGEN-3036): Duplicate macro definitions were found while processing the LEF files. This may indicate that the MergeLef program
should have been run before starting VOLTUS_LGEN.
Could you explain how to run MergeLef program ?
  • badhriu
    badhriu over 10 years ago
    if am not mistaken this is a warning message that can be ignored. I suspect this should be because you are providing antenna information with the same macro name. so the lef reader/merger is issuing an internal statement that you have twice (one as part of regular lef of macro/cells, and once during antenna) provided the macro name
  • Chith
    Thank you!
