  3. encounter report_analysis_coverage with untested pulsew...
  • Subscribers 93
  • Views 14035
encounter report_analysis_coverage with untested pulsewidth
zczc99
zczc99 over 9 years ago
I am using encounter  13.26 for place and route. But when I do report_analysis_coverage check, there are many  untested pulsewidth check violations.   When I further check the verbose, it shows me that the untested point happens on the reset pin of flip-flops. like
pin                          reference pin          check type        slack           reason
data_reg[0]/CD V       |    data_reg[0]  ^   |    pulsewidth  | untested | no endpoint clock
But the flip-flop does connect to a clock at the clock pin. How to understand the reason, and how to solve this ??
Thank you.
  • kazad
    kazad over 9 years ago
    Hi
    I guess 'data_reg[0]/CD' is a set/reset pin  - 'no endpoint clock' indicates that the set/reset line is not constrained.
    Hope this helps.
    Khandaker
