  3. Multi-CPU Encounter results vary due to overall CPU Uti...
  • Subscribers 92
  • Views 13514
Multi-CPU Encounter results vary due to overall CPU Utilization
Bob Ryan
Bob Ryan over 9 years ago
I have performed multiple Encounter runs of the same block using the foundation flow control scripts.  In this flow I use up to 5 local CPUs for the multi-cpu mode. I am using an 8 core machine with lots of memory but i share this machine with other team members.
I have seen significantly different results from the signoff phase based on the overall utilization of the machine.
If I perform a run during the day when the machine is moderately used the final signoff solution may not meet timing.
However, if I re-run this same process when the machine has no other (user) processes running I see very good results at signoff.
Can anyone explain this behavior?
Are there any system variables that control this behavior?
Bob
