  3. There is no .lib created with saveModel in Encounter, please...
  • Subscribers 94
  • Views 15050
There is no .lib created with saveModel in Encounter, please help!!
zczc99
zczc99 over 10 years ago
I am using soc encounter 13.26. I have finished a partition place&route, and I am trying to generate a .lib file for the top. In the document, it says the command "saveModel" can do this job, which is able to generate "LEF, timing library, DEF, FE DB".
But after I use this command, all the files except for the timing library is missing. Is there any particular reason for this.
The command I used is "saveModel -dir MODEL"
Please advise me.
Thank you
  • Kari
    Kari over 10 years ago
    sounds like this should have worked. were any errors or warnings issued? you may need to file a service request.
