  3. Unable to add VDD VSS pins to the verilog netlist generated...
  • Subscribers 94
  • Views 16950
Unable to add VDD VSS pins to the verilog netlist generated by Encounter
Kent Clark
Kent Clark over 10 years ago
I am using encounter EDI 11.
I want add VDD VSS pins to verilog netlist, but so far I am unsuccessful .
I have tried the following two commands with options -includePowerGround and -phys
1. saveNetlist -flat -includePowerGround $env(VLOGOUT_DIR)/$env(TOP_LEVEL).pnr.v
Writing Netlist ".././vlogout/MY_VERILOG_TOP.pnr.v" ...
**WARN: (ENCVL-516):    No Power/Ground connections in top module (MY_VERILOG_TOP).
0 Pwr names and 0 Gnd names.
2.  saveNetlist -flat -phys $env(VLOGOUT_DIR)/$env(TOP_LEVEL).pnr.v
Why is -phys option not working?
I am I doing something wrong here?
Is there any other way to add VDD VSS nets in verilog file?
Thanks in advance.
  • Kari
    Kari over 10 years ago
    did you declare your pwr/gnd nets in the .globals file? seems like encounter doesn't know that you have pwr/gnd nets or what they are called.
