  3. RE: path groups encounter timing analysis
  • Subscribers 95
  • Views 17607
kenambo
kenambo over 10 years ago
Hi All,
While doing timing analysis, I have a different path group as "reg2reg_temp.2234" instead of "reg2reg" path group. The path group is supposed to be reg2reg right?
Why this change? Is there anything else I can do to change this?
And in timing report, I have some paths in which launch clock is leading edge of a clock and capture clock is also the same clock with trailing edge. and the phase shift also 0.
Is this common for a timing path? or am I missing something?
Thanks.
  • TataPNRao
    TataPNRao over 10 years ago
    Can you please check which are data to data checks ?
    if yes, In general we are seeing this issue because of
    1.missing case analysis statements for scan pins (if you are seeing paths between SI to SE)
    2. Arc definition in  library data.
  • kenambo
    Hi
       Thanks. But this naming confusion is solved after I started design again in new directory.  Same files I am using.. but the path groups are back to default.. Dont know what caused the problem.
    Thanks.
