  3. Place multi-vt cells with Vt implant layer MinWidth req...
  • Subscribers 94
  • Views 19077
Place multi-vt cells with Vt implant layer MinWidth requirements
guilhermess
guilhermess over 10 years ago
I am trying to run placement on a test block that has many instances of an INVX1, which is 2 columns wide. I have 3 different flavors of INVX1 instances in the design: LVT, RVT and HVT.
Each of these Vt implant layers has a width requirement of at least 3 columns. So if SoC Encounter places in a row:
... [INVX1_RVT] [INVX1_LVT] [INVX1_RVT]...
The INVX1_LVT instance will trigger an LVT MinWidth violation.
My tech lef is coded as following:
LAYER LVT
  TYPE IMPLANT ;
  WIDTH <my_3_column_width_value> ;
END LVT
My std cell macros contain the obstructions for the Vt layers
MACRO INVX1_LVT
OBS
  LAYER LVT
    RECT 0.000 0.000 <my_2_column_width_value> <my_cell_height> ;
My question is: how to get SoC Encounter to place the cells to avoid MinWidth Vt violations? Encounter can correctly identify the MinWidth DRC violations but placeDesign or addFiller -fixDRC does not seem to solve it or take it into consideration.
The solution I'd expect is to have cells of the same Vt grouped together (or with a filler of the same Vt) to have at least the min width of 3 columns.
Thank you in advance.
Regards.
  • BobD
    BobD over 10 years ago +1
    The tool should handle this in version 14.2 or earlier, but only if you set this option: setPlaceMode -honorImplantSpacing true In newer versions of the tool this option is obsolete since the tool…
  • BobD
    In newer versions of the tool this option is obsolete since the tool honors implant min width/spacing automatically if specified in the tech lef.
    You might also want to have a SPACING rule for each implant layer (in addition to WIDTH which you already have).
    Hope this helps,
    Bob
