  3. secondary power pin routing
  • Subscribers 94
  • Views 17940
HansRey
HansRey over 10 years ago
I have a cell with a secondary power pin that needs routing. I'm trying a few strategies to route this pin:
1. setPGPinUseSignalRoute <cell>*: <net> -off
    routePGPinUseSignalRoute -nets {<net>}
2. sroute -secondaryPinNet <net> -powerDomains <powerdomain>
The first method is giving me the result I want, except for the routing width and amount of via's:
Since the power stripes are quite wide, and routing is done minimal width, I keep getting DRC errors
The second method is not giving me what I want, since it's routing full stripes horizontally over the chip, congesting my routing.
Any tips on how to handle this? Is there any way to adjust the routing type/width for the first method? Without adjusting the technology lef file?
Kind regards,
Hans
  • Kari
    Kari over 10 years ago
    Hi Hans,
    The usage doesn't look quite right. And you are turning it off with the -off switch. It should be:
    setPGPinUseSignalRoute cellName:pinName
    routePGPinUseSignalRoute -nets netName
    - Kari
