  3. Disconnecting the IO Port Net
  • Subscribers 93
  • Views 15832
Cyansparkle
Cyansparkle over 9 years ago
Hello folks!
I'm working on a block level design. How do I disconnect an IO port to the net which it is connecting to? Below is the situation:
IO port name: test1
test1 connects to net_x
addNet net_y
I need to disconnect test1 from net_x and connect it to net_y.
attachTerm/detachTerm works only for instance pins/nets but not for IO pins.
Any help would be greatly appreciated.
Thanks.
  • sobaesq
    sobaesq over 9 years ago
    Hi, did anybody get back to you about this?
  • Kari
    Kari over 9 years ago
    did you try the -port option of attachTerm? see the docs for detachTerm, regarding detaching a port and why it's not allowed.
