  3. AC limit fixing in Innovus - what data is needed in the...
  • Subscribers 95
  • Views 2019
AC limit fixing in Innovus - what data is needed in the ICT (and hence compiled qrcTech) files?
Brighty
Brighty over 10 years ago
When running verifyACLimit in Innovus I get the warnings:
**ERROR: (IMPVAC-96): Check QRC tech file if it doesn't contain EM rule or incorrect layer stacking information.
Type 'man IMPVAC-96' for more detail.
**WARN: (IMPVAC-116): Signal EM checking continue even No EM rule found in QRC tech or ICT EM file.
Can someone share an example of how this information would be described in the ICT file so I can check for it?
  • badhriu
    badhriu over 10 years ago
    the ICT files should contain em_* { constructs for each layer, as well as contain jrms/jpeak/jdc constructs. refer to Voltus documentation / QRC documentation of 15.x+ versions
