  3. name of path timing change
  • Subscribers 94
  • Views 15044
nhanle
nhanle over 9 years ago
Hi all,
I have just start for Place & Route, and I have a problem,
After CTS step and CTS_opt step, I see the name of path timing has changed, but number of paths not change. For example,
- After CTS, I have a path timing: MICRO/INSTR_DECODER/IR_reg[7]/q    (v) triggered by  leading edge of 'CLKM' ---> MICRO/ACCUMULATORS/ACC_B_reg[15]/d (^) checked with  leading edge of 'CLKM'
- After CTS_opt, I don't see this path timing, I just have: TLATCH_BLOCK/TLATCH_9A/TLATCHCELL_0/TLOUT_reg/q (v) triggered by leading edge of 'CLKM' ---> MICRO/ACCUMULATORS/ACC_B_reg[15]/d   (v) checked with leading edge of 'CLKM'.
I don't understand why, hope anyone can help me this problem ?
  • Kari
    Kari over 9 years ago
    are you just reporting the worst path? It is likely to be different before and after opt.
  • nhanle
    Thanks Kari
