  3. Netlist Modification in Encounter 14.1
  • Subscribers 94
  • Views 15098
kevinSh
kevinSh over 9 years ago
Hi All,
I believe the addPin command in the encounter tool was removed and only the addInst is available currently. Now how can I connect the pins of the cells that I insert in the netlist with addInst to the nets that I want when there is no addPin command??
Thank you.
  • BobD
    BobD over 9 years ago
    Would "attachTerm" meet your needs?
  • kevinSh
    It is still complaining that my terminal is not a signal terminal (I have a wire-only physical-only cell) but that was the correct command. Thanks.
