  3. Wire-only Primitives
  • Subscribers 94
  • Views 14646
kevinSh
kevinSh over 9 years ago
What is the best flow for inserting a wire-only primitives into a design?
I define a wire-only cell as a cell that only contains metal layers and vias not diffusion/poly layers (no transistors), and therefore it can placed on top of standard cells. I am currently using virtuoso and abstract to generate LEF and then inserting the LEF instances in the verilog netlist and performing ECO or  a clean PnR to insert them into the layout. I was wondering if there is a better way to do this mainly because the current approach doesn't seem to overlap these cells with standard cells. I guess the customVia command is in the same ball park, but not sure how to tell the tool to place custom vias in specific nets through netlist modification.
