  3. generate power grid library
  • Subscribers 94
  • Views 17722
MiladSh
MiladSh over 9 years ago
I have "qrcTechFile" file from foundry and I want to generate power grid library for dynamic power analysis but in "Set Power Library Mode" menu I don't know what's needed for "LEF-Tech Map" and how can I create a .map file.
Please help me with that.
Thanks in advance,
Milad
  • Kari
    Kari over 9 years ago
    Here is a sample file, hope it helps: (the .ict file is the human-readable version of the qrcTechFile)
    #2nd column is ict name, 4th column is lef name
    metal M1 lefdef M1
    metal M2 lefdef M2
    metal M3 lefdef M3
    metal M4 lefdef M4
    metal M5 lefdef M5
    metal M6 lefdef M6
    metal M7 lefdef M7
    metal M8 lefdef M8
    metal M9 lefdef M9
    metal M10 lefdef M10
    metal AP lefdef AP
    via VIA1 lefdef VIA1
    via VIA2 lefdef VIA2
    via VIA3 lefdef VIA3
    via VIA4 lefdef VIA4
    via VIA5 lefdef VIA5
    via VIA6 lefdef VIA6
    via VIA7 lefdef VIA7
    via VIA8 lefdef VIA8
    via VIA9 lefdef VIA9
    via RV lefdef RV
    poly poly lefdef PO
    via polyCont lefdef CO
  • MiladSh
    Hi, thanks for your reply.
    Actually I saw your 5min-tutorial for libGen and I have only "qrcTechFile" and don't have any other files that you mentioned there like stdcell.list and spice files. I was thinking only qrcTechFile is necessary but now unfortunately I believe that I can't generate power grid library.
    Milad
  • Kari
    The std.cell list is something you create, it's just a list of your std cells. You can generate the power grid library without spice, but it will be a bit less accurate.
  • MiladSh
    So you say that I can generate power grid library with only "qrcTechFile" and ".lef" file?
    And also how can I create a list of std cells?
    Milad
  • Kari
    You can, but I would ask the library vendor for the extracted spice for the std cells.
    There are probably lots of ways to create the list of std cells. I grep the LEF files for MACRO and then do some file manipulation to get it.
