  3. Encounter does not switch SDC between setup and hold ST...
  • Subscribers 94
  • Views 18076
Encounter does not switch SDC between setup and hold STA
Clidre
Clidre over 9 years ago
Hello, I'm designing a digital block with Encounter v14.26-s039_1. One input clock is a multiphase clock, programmable, coming from a custom analog block. In my MMMC view, I wrote two different .sdc files, one (called SS) to be used for the setup analysis (where I defined the multiphase clock with the first phase), the other (called FF) for the hold analysis  (multiphase clock defined with the last phase).
The problem is that when I run the timing analysis, Encounter considers ONLY the SS for both the setup and hold analysis. I don't know why it doesn't switch the sdc. Can you please help me to make it change the sdc to be considered for each analysis?
My mmmc.view file that I load with Import Design is the following:
create_rc_corner -name rc_nom \
-cap_table {../SYNTHESIS2/libs/lvt/capTbl_nom.capTbl} \
-preRoute_res {1.0} -preRoute_cap {1.0} -preRoute_clkres {0.0} -preRoute_clkcap {0.0} \
-postRoute_res {1.0} -postRoute_cap {1.0} -postRoute_xcap {1.0} -postRoute_clkres {0.0} -postRoute_clkcap {0.0} \
-qx_tech_file {/cadappl/iclibs/TSMC65/LP/1.7.A.2/Assura/lvs_rcx/qrcTechFile}
create_rc_corner -name rc_best_m55c \
-cap_table {../SYNTHESIS2/libs/lvt/capTbl_bc.capTbl} \
-T -55 \
create_rc_corner -name rc_worst_125c \
-cap_table {../SYNTHESIS2/libs/lvt/capTbl_wc.capTbl} \
-T 125 \
create_library_set -name core_typ -timing {../SYNTHESIS2/libs/lvt/core_tc.lib} -si {../SYNTHESIS2/libs/lvt/core_tc.cdb}
create_library_set -name core_bc -timing {../SYNTHESIS2/libs/lvt/core_bc.lib} -si {../SYNTHESIS2/libs/lvt/core_bc.cdb}
create_library_set -name core_wc -timing {../SYNTHESIS2/libs/lvt/core_wc.lib} -si {../SYNTHESIS2/libs/lvt/core_wc.cdb}
create_constraint_mode -name constraint_CKuncertSS -sdc_files {./sdc_encounterSS.sdc}
create_constraint_mode -name constraint_CKuncertFF -sdc_files {./sdc_encounterFF.sdc}
create_constraint_mode -name constraint_NOuncertTT -sdc_files {./sdc_encounterTT.sdc ./sdc_NOuncert.sdc}
create_constraint_mode -name constraint_NOuncertSS -sdc_files {./sdc_encounterSS.sdc ./sdc_NOuncert.sdc}
create_constraint_mode -name constraint_NOuncertFF -sdc_files {./sdc_encounterFF.sdc ./sdc_NOuncert.sdc}
create_delay_corner -name corner_typ -library_set {core_typ} -rc_corner {rc_nom}
create_delay_corner -name corner_min_m55c -library_set {core_bc} -rc_corner {rc_best_m55c}
create_delay_corner -name corner_max_125c -library_set {core_wc} -rc_corner {rc_worst_125c}
create_analysis_view -name setup_125c -constraint_mode {constraint_CKuncertSS} -delay_corner {corner_max_125c}
create_analysis_view -name hold_m55c -constraint_mode {constraint_CKuncertFF} -delay_corner {corner_min_m55c}
create_analysis_view -name data_gen_typ -constraint_mode {constraint_NOuncertTT} -delay_corner {corner_typ}
create_analysis_view -name setup_125c_NOuncert -constraint_mode {constraint_NOuncertSS} -delay_corner {corner_max_125c}
create_analysis_view -name hold_m55c_NOuncert -constraint_mode {constraint_NOuncertFF} -delay_corner {corner_min_m55c}
And, my commands for the timing analysis are:
set_analysis_view -setup {setup_125c_NOuncert} -hold {hold_m55c_NOuncert}
timeDesign -preCTS -idealClock -pathReports -drvReports -slackReports -numPaths 50 -prefix data_gen_preCTS -outDir timingReports
report_timing -machine_readable -max_points 10000 -max_slack 0.75 -path_exceptions all > ./myreports/trialroute.rpt
timeDesign -preCTS -hold -expandedViews
report_timing -machine_readable -max_points 10000 -max_slack 0.75 -path_exceptions all -early > ./myreports/trialroute_hold.rpt
If then I go to  Timing->Debug Timing... I can see that only the file  ./sdc_encounterSS.sdc has been used for both setup and hold analysis.
Thanks a lot for any feedback
  • Kari
    Kari over 9 years ago
    your file looks right, but it's possible my eyes missed something. i don't have a design handy that i can load, but maybe DebugTiming only looks at one view - i don't think i've ever looked at holds in debugTiming. If you do a reportTiming -early and -late, does it look like the right SDCs are used for each case?
  • MikeLW
    MikeLW over 9 years ago
    I'm not sure whether this is related to your problem, but I find that when I use Debug Timing, the Check Type setup/hold button doesn't work, and I get hold timing even if I've selected setup. If I want setup timing I have to issue the following command before doing Debug Timing:
    setAnalysisMode -checkType setup
    I think this is a bug in the Debug Timing GUI, where it doesn't pass the setup/hold option through to the report_timing command.
  • Clidre
    Thanks for your reply. I used reportTiming and it seems the SDCs are correct. Moreover, I tried with
    set_analysis_view -setup {setup_125c_NOuncert} -hold {setup_125c_NOuncert}
    and the results with DebugTiming are different. So it may be a bug in the GUI showing the same SDC for both the analysis
  • Clidre
    Hello, I haven't found your problem. I source a .tcl file with a set of commands like the following (example before the CTS):
    setAnalysisMode -analysisType bcwc -checkType setup -skew true -clockPropagation sdcControl
    And then I go to the GUI and I select Debug Timing to have a graphical representation of the violations. In this way, both the setup/hold options work
