  3. Routing in SoC Encounter
  • Subscribers 95
  • Views 15354
oAwad
oAwad over 9 years ago
Hello all,
 I use command "placeInstance" to place some instances in the core and route them manually since I want a certain routing pattern, then I run the automatic routing to place and route the rest of the design keeping my previous instances and routed wires as fixed. But I find that SoC Encounter ignores all pins connected to the pre-routed wires (the ones I manually routed and assigned to be fixed before automatic routing), so how to let the tool not ignore those pins in routing ?
I want my manually placed instances and manually routed wires to remain fixed, the rest of the design be automatically routed accordingly without ignoring any pins. How to do that ?
  • rmguttal
    rmguttal over 9 years ago
    That is strange. Because encounter usually doesn't touch hand routed nets especially since you set them as fixed. Try skipping those nets when you route the rest of the design.
    Another dirty method would be to specify those nets as special nets
  • Kari
    Kari over 9 years ago
    do you mean you aren't completely routing the special net? You make some of the connections, but you want nanoRoute to make the others? This can be tricky - you can try ecoRoute.
