  3. Constraining input signal in Encounter
  • Subscribers 94
  • Views 16118
mwb1
mwb1 over 9 years ago
I have a serial-to-parallel converter based on a shift register  and a bank of flip-flops that latches the data out. I synthesized this in dc_shell and p+r in Encounter.  My timing constraint file is below. clk is the serial clock and p_clk controls the output dffs.
[CODE]
set_wire_load_model -name "TSMC8K_Lowk_Aggresive"
set_wire_load_mode top
set_drive 0.5 [all_inputs]
set_load 1 [all_outputs]
set_max_capacitance 0.1 [all_inputs]
set_max_fanout 8 [get_designs]
set_max_fanout 8 [all_inputs]
#set_max_delay  1 -from [all_inputs]
create_clock clk -period 5 -waveform {0 2.5}
create_clock p_clk -period 340 -waveform {0 170}
set_dont_touch_network [all_clocks]
set_false_path -from clk -to p_clk
set_clock_uncertainty 0.5 clk
set_clock_uncertainty 0.5 p_clk
[\CODE]
Is it safe to assume that not specifying input delay constraints tells the tool that the data and clock to each dff is aligned? I can't find any reference to this in the dc_shell manual or synopsys constraint manual but I would hope that Encounter parses the .sdc/constraints in a similar way.
I dont correct setup and hold violations in dc_shell, I do that in encounter. The final netlist that encounter outputs shows delay cells have been added to the data input ports and looking at the timing arcs for each input, the delays are also shown. The delays push the data edge back to the next clock edge to satisfy the setup time, this makes sense to me.
[CODE]
Path 1: MET Setup Check with Pin sr_reg_0_/CP
Endpoint:   sr_reg_0_/D    (^) checked with  leading edge of 'clk'
Beginpoint: serial_data_in (^) triggered by  leading edge of '@'
Path Groups:  {inclkSrc2reg}
Other End Arrival Time          0.131
- Setup                         0.035
+ Phase Shift                   5.000
- Uncertainty                   0.500
= Required Time                 4.596
- Arrival Time                  3.592
= Slack Time                    1.004
     Clock Rise Edge                      0.000
     + Input Delay                        0.000
     + Drive Adjustment                   0.024
     = Beginpoint Arrival Time            0.024
     Timing Path:
     |         Instance         |       Arc        |  Cell   |  Slew | Delay | Arrival | Required |
     |                          |                  |         |       |       |  Time   |   Time   |
     |                          | serial_data_in ^ |         | 0.024 |       |   0.024 |    1.028 |
     | FE_PHC68_serial_data_in  | I ^ -> Z ^       | DEL015  | 0.046 | 0.286 |   0.310 |    1.314 |
     | FE_PHC362_serial_data_in | I ^ -> Z ^       | DEL005  | 0.026 | 0.066 |   0.376 |    1.380 |
     | FE_PHC910_serial_data_in | I ^ -> Z ^       | CKBD2   | 0.019 | 0.040 |   0.416 |    1.420 |
     | FE_PHC589_serial_data_in | I ^ -> Z ^       | DEL0    | 0.068 | 0.746 |   1.162 |    2.166 |
     | FE_PHC500_serial_data_in | I ^ -> Z ^       | DEL0    | 0.066 | 0.759 |   1.921 |    2.925 |
     | FE_PHC139_serial_data_in | I ^ -> Z ^       | DEL1    | 0.095 | 1.671 |   3.592 |    4.596 |
     | sr_reg_0_                | D ^              | DFCNQD1 | 0.095 | 0.000 |   3.592 |    4.596 |
     + Drive Adjustment                   0.012
     = Beginpoint Arrival Time            0.012
     Other End Path:
     |            |             |         |       |       |  Time   |   Time   |
     |            | clk ^       |         | 0.012 |       |   0.012 |   -0.992 |
     | clk__L1_I0 | I ^ -> ZN v | INVD24  | 0.014 | 0.013 |   0.025 |   -0.979 |
     | clk__L2_I0 | I v -> ZN ^ | CKND24  | 0.028 | 0.037 |   0.062 |   -0.942 |
     | clk__L3_I0 | I ^ -> ZN v | INVD24  | 0.020 | 0.033 |   0.095 |   -0.909 |
     | clk__L4_I1 | I v -> ZN ^ | CKND24  | 0.040 | 0.033 |   0.128 |   -0.876 |
     | sr_reg_0_  | CP ^        | DFCNQD1 | 0.040 | 0.003 |   0.131 |   -0.873 |
[\CODE]
Lastly, I simulate the p+r'd netlist in Virtuoso. The input serial data is changed at the rising clock edge and the circuit works fine.
So my question is, it appears that not having an input delay constraint tells dc_shell, Encounter, etc that the input data is aligned to the positive clock edge. Is this correct?
I should add, the input to the shift register is coming from an off-chip FPGA that I can also constrain. Therefore, I see no problem with using no input delay constraints because I can align the data with the clock edge at the FPGA.
