  3. SDF annotate
  • Subscribers 94
  • Views 17916
SDF annotate
subashrajam
subashrajam over 9 years ago
I synthesized the RTL code in RTL compiler. The SDF file was generated by using the command as write_sdf. Then i simulated the netlist by irun. The sdf annotation gives a warning such as following
ncelab: *W,SDFNET: Unable to annotate to non-existent timing check (RECREM (posedge CDN) (negedge CPN) (0) (0.363)) of instance tb.top_dbf_inst.dbf_32ch_inst.dbf_inst.debug_design_inst.\dbg_cd_dly_din0_reg[0] of module dfcfq1 <./delays.sdf, line 95617>.
could you help me to resolve this problem?
