  3. Cadence RTLCompiler, how to prevent re-synthesis of the...
  • Subscribers 94
  • Views 14966
Cadence RTLCompiler, how to prevent re-synthesis of the same module
Mathuria
Mathuria over 9 years ago
Hi ,
Say, in my top level verilog netlist i have a decoder module and it instantiates four instances of the same module DECODER.
After RTLCompiler has done elaborate and synthesis, they becomes instances of four differently-named modules, DECODER, DECODER_1667, DECODER_1668, and DECODER_1669 and each one has a different logic gate implementation.
How do I prevent the same module been renamed and re-synthesized to different implementations?
Later in hierarchical P&R, how do i handle this?  do I need to make one of the four copies as master partition, what is the command to make the other three into clones of the master partition?
can someone provide me a solution to this asap ...
  • Kari
    Kari over 9 years ago
    i don't know anything about synthesis, but for P&R, there is a master/clone flow you can use when doing top-level partitioning. it's in the user guide.
