  3. Exclude one clock from clock tree synthesis
  • Subscribers 94
  • Views 15744
Clidre
Clidre over 9 years ago
Hello all,
My digital system uses a multiphase clock. Each phase is defined as a independent clock. I have four phases defined in my .sdc file: CK1 CK2 CK3 and CK4. These 4 phases are generated with a custom IC design.
In order to meet the timing requirement, I need to avoid to have a clock tree for CK4. The buffer from the custom IC design will have the sufficient strenght to drive the clock line. Do you know which command I can use to avoid the placement of any buffer on the CK4 line? I'm using Enconter 14.26 and ccopt flow -integration native
Thanks!
  • Kari
    Kari over 8 years ago
    can you put a set_dont_touch on that net?
