  3. Genus cannot find ICG cells, although lib file provides...
  • Subscribers 95
  • Views 16212
Genus cannot find ICG cells, although lib file provides one
marten
marten over 9 years ago
Hi there,
building a digital design with clock gating fails with  Cadence Genus 16.12-s027_1 due to the lack of ICG in the provided libs:
genus@root:> syn_generic
Error   : Cannot find any usable integrated clock-gating cell. [POPT-78] [syn_generic]
        : The provided library does not have a usable integrated clock-gating cell.
When looking at the lib file (see below .lib-excerpt) there is one ICG named CGATE available, so why isn' it recognized probely?
 cell (CGATE_X1) {
    area : 4.6512;
    cell_leakage_power : 0.202986;
    pg_pin (gnd) {
      pg_type : primary_ground;
      voltage_name : "gnd";
    pg_pin (gnds) {
      voltage_name : "gnds";
    pg_pin (vdd) {
      pg_type : primary_power;
      voltage_name : "vdd";
    pg_pin (vdds) {
      voltage_name : "vdds";
    leakage_power () {
      value : 0;
      when : "(CLK * E * CLKG)";
      related_pg_pin : gnd;
    leakage_power () {
      value : 0;
      related_pg_pin : gnds;
    leakage_power () {
      value : 0.202589;
      related_pg_pin : vdd;
    leakage_power () {
      value : 1.21658e-05;
      related_pg_pin : vdds;
    leakage_power () {
      value : 0;
      when : "(CLK * E * !CLKG)";
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.193102;
    leakage_power () {
    leakage_power () {
      value : 0;
      when : "(CLK * !E * CLKG)";
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.212276;
    leakage_power () {
    leakage_power () {
      value : 0;
      when : "(CLK * !E * !CLKG)";
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.200839;
    leakage_power () {
    leakage_power () {
      value : 0;
      when : "(!CLK * E * !CLKG)";
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.200262;
    leakage_power () {
    leakage_power () {
      value : 0;
      when : "(!CLK * !E * !CLKG)";
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.208775;
    leakage_power () {
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0;
    leakage_power () {
      value : 0.202974;
    leakage_power () {
    pin (CLKG) {
      direction : output;
      function : "CLK";
      power_down_function : "(!vdd) + (gnd)";
      related_ground_pin : gnd;
      related_power_pin : vdd;
      max_capacitance : 0.028;
      timing () {
        related_pin : "CLK";
        sdf_cond : "E";
        timing_sense : positive_unate;
        timing_type : combinational_fall;
        when : "E";
        cell_fall (delay_template_clk_load1) {
          index_1 ("0.003, 0.01, 0.04, 0.08, 0.16, 0.35, 0.7, 1.4, 2.1, 4.2, 5.5");
          index_2 ("0.0002, 0.0018, 0.0035, 0.007, 0.014, 0.028");
          values ( \
            "0.0294879, 0.0398205, 0.0487314, 0.0659852, 0.0997817, 0.166978", \
            "0.0347069, 0.0450079, 0.0539224, 0.0711992, 0.105011, 0.17221", \
            "0.0573068, 0.0674414, 0.0763555, 0.0936854, 0.127599, 0.19488", \
            "0.0827644, 0.0935472, 0.102639, 0.119997, 0.153925, 0.221266", \
            "0.121645, 0.133974, 0.143449, 0.161033, 0.195035, 0.262336", \
            "0.188922, 0.20501, 0.215964, 0.234338, 0.268168, 0.335341", \
            "0.279023, 0.300261, 0.314115, 0.33507, 0.369837, 0.436259", \
            "0.412766, 0.441102, 0.459355, 0.485753, 0.524264, 0.590974", \
            "0.522671, 0.555589, 0.577107, 0.607928, 0.651148, 0.719878", \
            "0.793975, 0.835413, 0.864009, 0.904889, 0.960684, 1.03998", \
            "0.941375, 0.986205, 1.01809, 1.06391, 1.12607, 1.21278" \
        fall_transition (delay_template_clk_load1) {
          values ( \
            "0.0048524, 0.011077, 0.0178069, 0.0320752, 0.0609086, 0.11869", \
            "0.0048523, 0.0110798, 0.0178097, 0.0320727, 0.0609186, 0.118598", \
            "0.0049441, 0.011142, 0.0178398, 0.0320772, 0.0609039, 0.11869", \
            "0.0060777, 0.0118288, 0.0182344, 0.0321534, 0.060917, 0.118618", \
            "0.0084359, 0.0135443, 0.0194119, 0.0328451, 0.0612401, 0.118648", \
            "0.0133468, 0.0182387, 0.023092, 0.0347269, 0.0619731, 0.119299", \
            "0.020275, 0.025843, 0.03036, 0.039962, 0.063993, 0.120029", \
            "0.030526, 0.037527, 0.042541, 0.051512, 0.071082, 0.122183", \
            "0.038593, 0.04674, 0.052327, 0.061738, 0.079695, 0.125872", \
            "0.058078, 0.0684, 0.07566, 0.086808, 0.105286, 0.143345", \
            "0.068312, 0.079434, 0.087614, 0.099809, 0.119355, 0.156112" \
        receiver_capacitance1_rise (delay_template_clk_load1) {
          index_2 ("0");
          values ( \
            "0.00101277", \
            "0.00107731", \
            "0.00111709", \
            "0.00113738", \
            "0.00115087", \
            "0.00116475", \
            "0.00117439", \
            "0.0011856", \
            "0.00119271", \
            "0.00120462", \
            "0.00120931" \
        receiver_capacitance2_rise (delay_template_clk_load1) {
          index_2 ("0");
          values ( \
            "0.00125816", \
            "0.00139447", \
            "0.00155052", \
            "0.00170294", \
            "0.00199777", \
            "0.00233997", \
            "0.00293755", \
            "0.00291149", \
            "0.00289583", \
            "0.00286674", \
            "0.0028518" \
        output_current_fall () {
          vector (ccs_template) {
            reference_time : 0.00375;
            index_1 ("0.003");
            index_2 ("0.0002");
            index_3 ("0.0246521, 0.0294609, 0.0307928, 0.0332411, 0.0344262, 0.0356106, 0.0386795, 0.0402228, 0.0417247, 0.0425176, 0.0437401, 0.0458277, 0.047597, 0.0509265, 0.0559515");
            values ( \
              "-0.00237731, -0.0142754, -0.0157612, -0.0170134, -0.0167729, -0.0160253, -0.00790806, -0.00462428, -0.00260775, -0.00193246, -0.00121756, -0.000616405, -0.000380630, -0.000174872, -0.000111978" \
            index_1 ("0.003");
            index_2 ("0.0018");
            index_3 ("0.0271955, 0.0304305, 0.0353129, 0.0381565, 0.0408834, 0.0435783, 0.0462722, 0.0476278, 0.0577542, 0.0617993, 0.0643354, 0.0693825, 0.0753371, 0.0823776, 0.0907041");
            values ( \
              "-0.00773306, -0.0479933, -0.0615546, -0.0651273, -0.0669155, -0.0667825, -0.0647750, -0.0622375, -0.0255678, -0.0150468, -0.0105742, -0.00510329, -0.00210180, -0.000676775, -0.000170739" \
            index_1 ("0.003");
            index_2 ("0.0035");
            index_3 ("0.0271981, 0.0322474, 0.0348815, 0.0384363, 0.0417851, 0.0472971, 0.052493, 0.0580799, 0.0617319, 0.0758324, 0.0798893, 0.0868814, 0.0940256, 0.100999, 0.108969, 0.112152");
            values ( \
              "-0.00702388, -0.0623686, -0.0706010, -0.0773701, -0.0805144, -0.0820614, -0.0807076, -0.0753592, -0.0680004, -0.0299576, -0.0220295, -0.0123716, -0.00665919, -0.00364192, -0.00170055, -0.00151154" \
            index_1 ("0.003");
            index_2 ("0.007");
            index_3 ("0.0295021, 0.0319286, 0.0348596, 0.0385301, 0.0448101, 0.0469122, 0.0538317, 0.0620373, 0.0697375, 0.0777714, 0.0865582, 0.110917, 0.119516, 0.130838, 0.138739, 0.148055, 0.163423, 0.180764");
            values ( \
              "-0.0495943, -0.0660748, -0.0772033, -0.0854117, -0.0914176, -0.0923290, -0.0930038, -0.0918835, -0.0895854, -0.0848331, -0.0745245, -0.0345353, -0.0243132, -0.0146287, -0.0101458, -0.00651709, -0.00306924, -0.00140530" \
            index_1 ("0.003");
            index_2 ("0.014");
            index_3 ("0.0295039, 0.0339847, 0.0389381, 0.0443878, 0.0501932, 0.056869, 0.0745651, 0.0889135, 0.105133, 0.111398, 0.118804, 0.13553, 0.169308, 0.186938, 0.203309, 0.215663, 0.229175, 0.251352, 0.264749, 0.28006, 0.310682, 0.35717, 0.414118");
            values ( \
              "-0.0473509, -0.0777602, -0.0906955, -0.0968044, -0.0991109, -0.0996649, -0.0985788, -0.0969332, -0.0938705, -0.0920507, -0.0890961, -0.0780940, -0.0465386, -0.0326125, -0.0227284, -0.0170694, -0.0123734, -0.00717509, -0.00515275, -0.00350324, -0.00156326, -0.000406454, -6.84710e-05" \
            index_1 ("0.003");
            index_2 ("0.028");
            index_3 ("0.0322277, 0.0488888, 0.0510915, 0.0579664, 0.0631652, 0.10052, 0.141952, 0.15221, 0.170801, 0.185197, 0.200497, 0.23062, 0.299758, 0.332462, 0.365874, 0.39, 0.416336, 0.448813, 0.463773, 0.486472, 0.516737, 0.577268, 0.621434");
            values ( \
              "-0.100917, -0.101909, -0.102581, -0.103316, -0.103367, -0.101985, -0.0995768, -0.0987034, -0.0967594, -0.0946230, -0.0914002, -0.0811303, -0.0472814, -0.0337326, -0.0231584, -0.0174064, -0.0126414, -0.00841076, -0.00697336, -0.00523618, -0.00355603, -0.00157196, -0.00101145" \
            reference_time : 0.0125;
            index_1 ("0.01");
            index_2 ("0.0002");
            index_3 ("0.03877, 0.04343, 0.0447619, 0.0472102, 0.0483952, 0.0495796, 0.0526508, 0.0541894, 0.0556956, 0.0564878, 0.0577098, 0.0597938, 0.0615596, 0.0648967, 0.076876");
            values ( \
              "-0.00285961, -0.0143250, -0.0157129, -0.0169676, -0.0168187, -0.0159812, -0.00790493, -0.00462650, -0.00260736, -0.00193011, -0.00121870, -0.000618126, -0.000380047, -0.000175876, -2.45523e-05" \
            index_1 ("0.01");
            index_2 ("0.0018");
            index_3 ("0.0414679, 0.043151, 0.0443499, 0.0492478, 0.0520917, 0.0548199, 0.0575157, 0.0603404, 0.0629393, 0.0717955, 0.0745018, 0.0780114, 0.0833143, 0.0898945, 0.0949351");
            values ( \
              "-0.000253436, -0.0425896, -0.0476241, -0.0613492, -0.0652104, -0.0667664, -0.0668894, -0.0644948, -0.0585554, -0.0252564, -0.0178138, -0.0109803, -0.00510327, -0.00190320, -0.00133453" \
            index_1 ("0.01");
            index_2 ("0.0035");
            index_3 ("0.0414688, 0.0453748, 0.0511818, 0.0557606, 0.0610863, 0.0642419, 0.0695285, 0.073119, 0.0895101, 0.0954383, 0.102348, 0.106979, 0.112295, 0.125064, 0.154027");
            values ( \
              "-0.00568081, -0.0590594, -0.0754883, -0.0805355, -0.0821065, -0.0816641, -0.0785505, -0.0735589, -0.0305110, -0.0194204, -0.0109686, -0.00722781, -0.00452255, -0.00135716, -1.00000e-22" \
            index_1 ("0.01");
            index_2 ("0.007");
            index_3 ("0.0414692, 0.0488241, 0.0530941, 0.057034, 0.0608846, 0.0650032, 0.0721977, 0.0815575, 0.0917343, 0.0998593, 0.127141, 0.135387, 0.145652, 0.161975, 0.184664, 0.185267");
            values ( \
              "-0.0180213, -0.0772603, -0.0864812, -0.0905619, -0.0923941, -0.0930411, -0.0926196, -0.0904309, -0.0846692, -0.0755646, -0.0315101, -0.0224323, -0.0140474, -0.00649633, -0.00209957, -0.00207480" \
            index_1 ("0.01");
            index_2 ("0.014");
            index_3 ("0.0439502, 0.0479667, 0.0529167, 0.0582683, 0.0641239, 0.0708269, 0.0885441, 0.102892, 0.121112, 0.132784, 0.148243, 0.184801, 0.202012, 0.216618, 0.22714, 0.246148, 0.260817, 0.27626, 0.288117, 0.311833, 0.356186, 0.40893");
            values ( \
              "-0.0616995, -0.0778589, -0.0907548, -0.0967803, -0.0991384, -0.0997003, -0.0986127, -0.0969664, -0.0933461, -0.0890977, -0.0791558, -0.0452255, -0.0318725, -0.0230858, -0.0181030, -0.0115110, -0.00802808, -0.00548581, -0.00407844, -0.00221428, -0.000628555, -0.000126329" \
            index_1 ("0.01");
            index_2 ("0.028");
            index_3 ("0.0440023, 0.0495735, 0.0547585, 0.0600224, 0.0671909, 0.0736851, 0.0844426, 0.128358, 0.165666, 0.184783, 0.204122, 0.214487, 0.235217, 0.24701, 0.315156, 0.349753, 0.378489, 0.39903, 0.436208, 0.465018, 0.49545, 0.518834, 0.565602, 0.629145");
            values ( \
              "-0.0596128, -0.0852450, -0.0961841, -0.100857, -0.103000, -0.103393, -0.103241, -0.101317, -0.0987482, -0.0967585, -0.0937108, -0.0913968, -0.0849001, -0.0800261, -0.0466098, -0.0325216, -0.0235124, -0.0184471, -0.0117435, -0.00818322, -0.00558204, -0.00414727, -0.00224229, -0.00107300" \
            reference_time : 0.05;
            index_1 ("0.04");
            index_2 ("0.0002");
            index_3 ("0.097896, 0.103404, 0.104799, 0.10731, 0.108512, 0.109714, 0.112987, 0.114382, 0.115819, 0.116624, 0.117855, 0.119989, 0.121802, 0.129011, 0.12954");
            values ( \
              "-0.00105330, -0.0134823, -0.0151948, -0.0167212, -0.0165853, -0.0158834, -0.00741501, -0.00453972, -0.00263574, -0.00193841, -0.00122579, -0.000614056, -0.000370212, -8.92145e-05, -8.51531e-05" \
            index_1 ("0.04");
            index_2 ("0.0018");
            index_3 ("0.101291, 0.102568, 0.105841, 0.109994, 0.111985, 0.115768, 0.117452, 0.119711, 0.12114, 0.132495, 0.135911, 0.139525, 0.144881, 0.151303, 0.167812");
            values ( \
              "-0.0201748, -0.0363736, -0.0509316, -0.0614579, -0.0642368, -0.0665269, -0.0665092, -0.0650189, -0.0628363, -0.0230518, -0.0146403, -0.00880545, -0.00404681, -0.00155012, -0.000101116" \
            index_1 ("0.04");
            index_2 ("0.0035");
            index_3 ("0.101367, 0.10388, 0.105839, 0.108601, 0.113364, 0.117765, 0.121838, 0.126367, 0.129985, 0.132442, 0.14998, 0.154528, 0.160311, 0.169085, 0.179839, 0.191411, 0.205211");
            values ( \
              "-0.00704689, -0.0487557, -0.0584359, -0.0683388, -0.0776748, -0.0810760, -0.0818445, -0.0806283, -0.0779012, -0.0745378, -0.0294390, -0.0207504, -0.0129008, -0.00605567, -0.00229276, -0.000730702, -0.000171713" \
            index_1 ("0.04");
            index_2 ("0.007");
            index_3 ("0.101351, 0.105601, 0.108657, 0.111082, 0.115444, 0.120846, 0.127594, 0.132997, 0.141657, 0.147601, 0.151721, 0.159846, 0.176462, 0.187351, 0.200971, 0.210998, 0.218594, 0.226484, 0.244613, 0.260574");
            values ( \
              "-0.00387028, -0.0620807, -0.0747660, -0.0814943, -0.0884843, -0.0920026, -0.0928594, -0.0923560, -0.0902860, -0.0876475, -0.0847651, -0.0754687, -0.0473346, -0.0313039, -0.0174320, -0.0110371, -0.00769849, -0.00529390, -0.00217212, -0.00109667" \
            index_1 ("0.04");
            index_2 ("0.014");
            index_3 ("0.10477, 0.116657, 0.120243, 0.124405, 0.132556, 0.145408, 0.16298, 0.179231, 0.185623, 0.192871, 0.209592, 0.242526, 0.260262, 0.271173, 0.282811, 0.297981, 0.307931, 0.327494, 0.338959, 0.361889, 0.402594, 0.450532");
            values ( \
              "-0.0813672, -0.0948594, -0.0975163, -0.0989256, -0.0995592, -0.0988131, -0.0968742, -0.0938630, -0.0919981, -0.0890958, -0.0780942, -0.0472817, -0.0331281, -0.0261348, -0.0200452, -0.0140357, -0.0110445, -0.00682875, -0.00513326, -0.00285483, -0.000922541, -0.000228765" \
            index_1 ("0.04");
            index_2 ("0.028");
            index_3 ("0.103862, 0.109783, 0.114204, 0.120179, 0.123799, 0.127262, 0.133855, 0.156173, 0.188528, 0.227099, 0.244953, 0.259352, 0.274649, 0.304772, 0.373916, 0.406614, 0.424825, 0.440022, 0.464151, 0.490494, 0.522967, 0.537924, 0.560617, 0.590874, 0.651387, 0.74131, 0.851534");
            values ( \
              "-0.0549688, -0.0841819, -0.0944700, -0.100576, -0.102109, -0.102841, -0.103293, -0.102747, -0.101244, -0.0986385, -0.0967592, -0.0946227, -0.0914000, -0.0811304, -0.0472784, -0.0337324, -0.0275674, -0.0231597, -0.0174067, -0.0126406, -0.00841049, -0.00697331, -0.00523653, -0.00355689, -0.00157254, -0.000424633, -7.01601e-05" \
            reference_time : 0.1;
            index_1 ("0.08");
            index_2 ("0.0002");
            index_3 ("0.171947, 0.175472, 0.179594, 0.182765, 0.184223, 0.185672, 0.187277, 0.190365, 0.191848, 0.193465, 0.19556, 0.196905, 0.198698, 0.199912");
            values ( \
              "-0.00398928, -0.00780102, -0.0115816, -0.0135680, -0.0139440, -0.0136863, -0.0112426, -0.00485276, -0.00287435, -0.00162801, -0.000807401, -0.000554617, -0.000368420, -0.000295457" \
            index_1 ("0.08");
            index_2 ("0.0018");
            index_3 ("0.172499, 0.178025, 0.180488, 0.184368, 0.187648, 0.190659, 0.193555, 0.196439, 0.199323, 0.20943, 0.212806, 0.216993, 0.221114, 0.228329");
            values ( \
              "-0.000215574, -0.0323536, -0.0408252, -0.0516647, -0.0579531, -0.0614873, -0.0629057, -0.0619857, -0.0566346, -0.0216394, -0.0138234, -0.00766014, -0.00421524, -0.00164495" \
            index_1 ("0.08");
            index_2 ("0.0035");
            index_3 ("0.172507, 0.18235, 0.186165, 0.192551, 0.196038, 0.2, 0.204391, 0.207148, 0.211171, 0.22816, 0.233922, 0.240844, 0.247577, 0.257626");
            values ( \
              "-0.00152639, -0.0541346, -0.0655267, -0.0761273, -0.0785234, -0.0793439, -0.0784023, -0.0762465, -0.0696428, -0.0257135, -0.0162430, -0.00904613, -0.00502879, -0.00241630" \
            index_1 ("0.08");
            index_2 ("0.007");
            index_3 ("0.17251, 0.186066, 0.193167, 0.198004, 0.206867, 0.212284, 0.218212, 0.223577, 0.228036, 0.236823, 0.255307, 0.26426, 0.277346, 0.287257, 0.294879, 0.302869, 0.321259, 0.343729, 0.370364");
            values ( \
              "-0.00304928, -0.0719719, -0.0857725, -0.0895231, -0.0918169, -0.0914941, -0.0900836, -0.0877883, -0.0847596, -0.0744693, -0.0432622, -0.0305752, -0.0174011, -0.0110632, -0.00772001, -0.00528542, -0.00214345, -0.000635911, -0.000130471" \
            index_1 ("0.08");
            index_2 ("0.014");
            index_3 ("0.177068, 0.18295, 0.188607, 0.19219, 0.197559, 0.205821, 0.211962, 0.224964, 0.24328, 0.251233, 0.259335, 0.269203, 0.285941, 0.316378, 0.335911, 0.345416, 0.356279, 0.366195, 0.377863, 0.39342, 0.40354, 0.419118, 0.439888, 0.481375, 0.529829");
            values ( \
              "-0.0309044, -0.0644374, -0.0828015, -0.0896075, -0.0950882, -0.0984709, -0.0991203, -0.0984860, -0.0962948, -0.0948542, -0.0928265, -0.0891007, -0.0780939, -0.0495104, -0.0336276, -0.0273901, -0.0214298, -0.0170205, -0.0128989, -0.00881747, -0.00687719, -0.00467168, -0.00274781, -0.000867504, -0.000207526" \
            index_1 ("0.08");
            index_2 ("0.028");
            index_3 ("0.180955, 0.2, 0.205536, 0.214867, 0.224167, 0.264917, 0.306848, 0.321337, 0.351074, 0.365318, 0.381597, 0.454793, 0.484113, 0.514989, 0.535531, 0.572709, 0.601519, 0.631948, 0.655329, 0.702091, 0.766286");
            values ( \
              "-0.0865964, -0.0996182, -0.101926, -0.103078, -0.103042, -0.101244, -0.0983328, -0.0967592, -0.0914086, -0.0872180, -0.0809058, -0.0451844, -0.0332927, -0.0235112, -0.0184493, -0.0117418, -0.00818531, -0.00558430, -0.00414577, -0.00224459, -0.00104937" \
            reference_time : 0.2;
            index_1 ("0.16");
            index_2 ("0.0002");
            index_3 ("0.304425, 0.305706, 0.313129, 0.319512, 0.323648, 0.325586, 0.327521, 0.330909, 0.332737, 0.334652, 0.336321, 0.338596, 0.340457, 0.344179, 0.350051");
            values ( \
              "-0.00167272, -0.00207909, -0.00604365, -0.00897125, -0.0102864, -0.0103982, -0.00927656, -0.00464154, -0.00268445, -0.00143473, -0.000836781, -0.000457788, -0.000317946, -0.000190477, -0.000140403" \
            index_1 ("0.16");
            index_2 ("0.0018");
            index_3 ("0.305689, 0.313807, 0.322861, 0.330627, 0.333982, 0.335453, 0.337221, 0.34115, 0.35136, 0.354658, 0.358022, 0.363496, 0.370118, 0.377813, 0.387022");
            values ( \
              "-0.000201056, -0.0207701, -0.0398041, -0.0520461, -0.0550621, -0.0557495, -0.0558028, -0.0508440, -0.0199386, -0.0130809, -0.00830137, -0.00386497, -0.00149921, -0.000464948, -0.000106861" \
            index_1 ("0.16");
            index_2 ("0.0035");
            index_3 ("0.305689, 0.325563, 0.328369, 0.33379, 0.33819, 0.343473, 0.348182, 0.353209, 0.367785, 0.373929, 0.379511, 0.38352, 0.388905, 0.399786, 0.40731, 0.407753");
            values ( \
              "-0.000159722, -0.0541995, -0.0600195, -0.0685417, -0.0727668, -0.0746487, -0.0730027, -0.0657100, -0.0292422, -0.0182934, -0.0115863, -0.00826489, -0.00517020, -0.00193575, -0.00100154, -0.000980865" \
            index_1 ("0.16");
            index_2 ("0.007");
            index_3 ("0.305689, 0.33161, 0.336999, 0.34134, 0.345207, 0.353131, 0.361053, 0.368976, 0.372607, 0.378073, 0.405387, 0.414494, 0.427838, 0.439029, 0.453024, 0.458554");
            values ( \
              "-0.00105284, -0.0743744, -0.0821265, -0.0858855, -0.0877483, -0.0890488, -0.0877497, -0.0838060, -0.0805710, -0.0737488, -0.0311752, -0.0212912, -0.0116677, -0.00687998, -0.00351453, -0.00282729" \
            index_1 ("0.16");
            index_2 ("0.014");
            index_3 ("0.315601, 0.323057, 0.331165, 0.340484, 0.346245, 0.351385, 0.358685, 0.365826, 0.385175, 0.396843, 0.410399, 0.417545, 0.427058, 0.46066, 0.477891, 0.497757, 0.51833, 0.532901, 0.550594, 0.562557, 0.586482, 0.628397, 0.678089");
            values ( \
              "-0.0536812, -0.0570146, -0.0786259, -0.0917632, -0.0952127, -0.0966870, -0.0973146, -0.0972218, -0.0952913, -0.0931634, -0.0889725, -0.0851219, -0.0781200, -0.0467530, -0.0330618, -0.0212872, -0.0131250, -0.00919821, -0.00595108, -0.00441476, -0.00238479, -0.000738885, -0.000169671" \
            index_1 ("0.16");
            index_2 ("0.028");
            index_3 ("0.319635, 0.333016, 0.340414, 0.345862, 0.3507, 0.358745, 0.367714, 0.410047, 0.443426, 0.462405, 0.494292, 0.507197, 0.524648, 0.590236, 0.624006, 0.663886, 0.702376, 0.729632, 0.767518, 0.793079, 0.844203, 0.89501");
            values ( \
              "-0.0822840, -0.0851674, -0.0952043, -0.0988149, -0.100538, -0.101651, -0.101906, -0.100873, -0.0987408, -0.0967569, -0.0908536, -0.0869416, -0.0800375, -0.0478145, -0.0337647, -0.0214790, -0.0135351, -0.00964993, -0.00599836, -0.00433207, -0.00220511, -0.00126919" \
            reference_time : 0.4375;
            index_1 ("0.35");
            index_2 ("0.0002");
            index_3 ("0.59527, 0.60412, 0.614866, 0.619265, 0.626432, 0.629586, 0.632608, 0.635626, 0.64313, 0.644985, 0.646821, 0.648241, 0.651192, 0.655125, 0.68911");
            values ( \
              "-6.66447e-05, -0.00177101, -0.00413040, -0.00497679, -0.00613423, -0.00652657, -0.00673716, -0.00642643, -0.00180612, -0.00108798, -0.000637825, -0.000429178, -0.000206678, -0.000112431, -1.57886e-05" \
            index_1 ("0.35");
            index_2 ("0.0018");
            index_3 ("0.599325, 0.607152, 0.613197, 0.6162, 0.632759, 0.637913, 0.642523, 0.646802, 0.651006, 0.655199, 0.662266, 0.664263, 0.666888, 0.669641, 0.671501, 0.674109, 0.675167, 0.677282, 0.681512, 0.68438");
            values ( \
              "-0.00352489, -0.00751199, -0.0128384, -0.0157536, -0.0325911, -0.0372683, -0.0408950, -0.0431551, -0.0426899, -0.0364673, -0.0203984, -0.0164659, -0.0121281, -0.00866814, -0.00684691, -0.00489897, -0.00427164, -0.00325969, -0.00187799, -0.00143651" \
            index_1 ("0.35");
            index_2 ("0.0035");
            index_3 ("0.602026, 0.607158, 0.616061, 0.637449, 0.641449, 0.647748, 0.653465, 0.658963, 0.664445, 0.666132, 0.676107, 0.682461, 0.688915, 0.691796, 0.695637, 0.701814, 0.705958, 0.713639");
            values ( \
              "-0.00565073, -0.00871717, -0.0184814, -0.0474683, -0.0523754, -0.0590034, -0.0631812, -0.0645471, -0.0605981, -0.0579334, -0.0361078, -0.0236046, -0.0144400, -0.0114698, -0.00835758, -0.00497662, -0.00348891, -0.00179697" \
            index_1 ("0.35");
            index_2 ("0.007");
            index_3 ("0.607201, 0.617402, 0.644943, 0.654665, 0.663432, 0.67186, 0.680287, 0.684194, 0.688163, 0.716243, 0.724066, 0.735652, 0.742829, 0.748924, 0.757108, 0.76802, 0.788408");
            values ( \
              "-0.0104639, -0.0224506, -0.0667173, -0.0773062, -0.0824637, -0.0837405, -0.0812429, -0.0782909, -0.0739954, -0.0315809, -0.0228929, -0.0137401, -0.00987031, -0.00742410, -0.00504292, -0.00296232, -0.00102976" \
            index_1 ("0.35");
            index_2 ("0.014");
            index_3 ("0.61156, 0.622274, 0.643821, 0.651888, 0.660933, 0.674463, 0.685001, 0.690777, 0.705706, 0.713226, 0.721159, 0.735875, 0.776673, 0.794667, 0.815298, 0.826104, 0.840511, 0.855544, 0.875, 0.907173, 0.932258");
            values ( \
              "-0.0203106, -0.0319943, -0.0714586, -0.0823695, -0.0900761, -0.0947612, -0.0951247, -0.0947927, -0.0927597, -0.0909229, -0.0880066, -0.0791586, -0.0424182, -0.0292888, -0.0183845, -0.0142626, -0.0100443, -0.00694643, -0.00428122, -0.00197406, -0.00130240" \
            index_1 ("0.35");
            index_2 ("0.028");
            index_3 ("0.620547, 0.640227, 0.650012, 0.658642, 0.66745, 0.672751, 0.680627, 0.688238, 0.716021, 0.74136, 0.76112, 0.772913, 0.794896, 0.802782, 0.818029, 0.835389, 0.897075, 0.932015, 0.961633, 0.985603, 1.00818, 1.03829, 1.05784, 1.07987, 1.10926, 1.16803, 1.25277, 1.35601");
            values ( \
              "-0.0501181, -0.0685516, -0.0842687, -0.0931210, -0.0978672, -0.0993501, -0.100504, -0.100863, -0.100282, -0.0989547, -0.0974208, -0.0961944, -0.0927483, -0.0909979, -0.0865648, -0.0798012, -0.0496805, -0.0348380, -0.0250361, -0.0188881, -0.0143914, -0.00990315, -0.00775527, -0.00587774, -0.00403579, -0.00183877, -0.000542679, -0.000111377" \
            reference_time : 0.875;
            index_1 ("0.7");
            index_2 ("0.0002");
            index_3 ("1.10437, 1.10896, 1.11345, 1.11815, 1.13657, 1.1478, 1.15403, 1.15886, 1.16345, 1.16801, 1.17142, 1.17862, 1.18209, 1.18581, 1.18901, 1.19473, 1.22678");
            values ( \
              "-0.000234689, -0.000348780, -0.000568967, -0.000893795, -0.00274723, -0.00364113, -0.00402865, -0.00427204, -0.00442854, -0.00437025, -0.00374963, -0.00132821, -0.000620107, -0.000260324, -0.000124739, -4.50124e-05, -2.62477e-05" \
            index_1 ("0.7");
            index_2 ("0.0018");
            index_3 ("1.11196, 1.12313, 1.13109, 1.14056, 1.16126, 1.17528, 1.18132, 1.18711, 1.19289, 1.20345, 1.20814, 1.21098, 1.21476, 1.21759, 1.21958, 1.22355, 1.2315, 1.24194, 1.27139");
            values ( \
              "-0.00175840, -0.00469042, -0.00781762, -0.0122524, -0.0225283, -0.0287138, -0.0307638, -0.0315616, -0.0284798, -0.0142193, -0.00896851, -0.00659289, -0.00426601, -0.00307359, -0.00244159, -0.00154735, -0.000661607, -0.000302117, -4.35217e-05" \
            index_1 ("0.7");
            index_2 ("0.0035");
            index_3 ("1.12081, 1.13534, 1.14874, 1.18147, 1.18914, 1.19624, 1.2032, 1.21014, 1.22511, 1.23061, 1.23839, 1.24234, 1.24809, 1.25575, 1.26647");
            values ( \
              "-0.00715299, -0.0116596, -0.0204250, -0.0434230, -0.0478318, -0.0506739, -0.0501054, -0.0428227, -0.0195764, -0.0133135, -0.00740026, -0.00543700, -0.00344361, -0.00185498, -0.000809868" \
            index_1 ("0.7");
            index_2 ("0.007");
            index_3 ("1.1252, 1.13608, 1.13967, 1.18943, 1.20023, 1.21008, 1.2196, 1.23117, 1.26181, 1.27172, 1.28172, 1.29764, 1.31293");
            values ( \
              "-0.0130703, -0.0135393, -0.0161468, -0.0609305, -0.0686703, -0.0733141, -0.0741891, -0.0665708, -0.0257758, -0.0169999, -0.0108990, -0.00520998, -0.00267877" \
            index_1 ("0.7");
            index_2 ("0.014");
            index_3 ("1.13361, 1.15087, 1.18536, 1.19648, 1.21368, 1.22943, 1.24488, 1.26031, 1.2652, 1.2777, 1.3083, 1.32984, 1.34158, 1.35484, 1.36962, 1.39181, 1.40347, 1.41903, 1.45014, 1.46941");
            values ( \
              "-0.0221185, -0.0273370, -0.0652275, -0.0758695, -0.0868657, -0.0908790, -0.0906698, -0.0868600, -0.0846751, -0.0766087, -0.0492690, -0.0323630, -0.0251202, -0.0185739, -0.0131315, -0.00766132, -0.00575030, -0.00389472, -0.00171727, -0.00117826" \
            index_1 ("0.7");
            index_2 ("0.028");
            index_3 ("1.14457, 1.17409, 1.19457, 1.20908, 1.22567, 1.25111, 1.28244, 1.30482, 1.32435, 1.34134, 1.36914, 1.3742, 1.43356, 1.47256, 1.50176, 1.52366, 1.54921, 1.58329, 1.60476, 1.64067, 1.67184, 1.72803, 1.75, 1.8648");
            values ( \
              "-0.0385137, -0.0563741, -0.0797946, -0.0910269, -0.0973496, -0.0995073, -0.0981130, -0.0963521, -0.0939023, -0.0905824, -0.0816401, -0.0795083, -0.0506294, -0.0341526, -0.0246663, -0.0190889, -0.0140373, -0.00917471, -0.00701457, -0.00445009, -0.00298496, -0.00140621, -0.00106269, -0.000245656" \
            reference_time : 1.75;
            index_1 ("1.4");
            index_2 ("0.0002");
            index_3 ("2.08926, 2.10323, 2.11097, 2.13672, 2.14652, 2.15503, 2.17006, 2.17705, 2.18392, 2.18906, 2.20251, 2.20718, 2.21115, 2.21823, 2.22676, 2.25475");
            values ( \
              "-0.000188397, -0.000384935, -0.000630221, -0.00185922, -0.00222324, -0.00248224, -0.00281907, -0.00291477, -0.00291593, -0.00262284, -0.000563973, -0.000249473, -0.000122585, -3.59400e-05, -2.26333e-05, -1.68669e-05" \
            index_1 ("1.4");
            index_2 ("0.0018");
            index_3 ("2.10244, 2.11942, 2.13224, 2.18152, 2.19991, 2.20827, 2.2166, 2.21725, 2.23691, 2.24372, 2.24841, 2.25212, 2.25954, 2.27115, 2.32599");
            values ( \
              "-0.00271550, -0.00374641, -0.00637249, -0.0178286, -0.0211733, -0.0220452, -0.0209604, -0.0206611, -0.00669091, -0.00354983, -0.00221567, -0.00149983, -0.000655619, -0.000206115, -5.26100e-05" \
            index_1 ("1.4");
            index_2 ("0.0035");
            index_3 ("2.11085, 2.13373, 2.15163, 2.18626, 2.19855, 2.20939, 2.2193, 2.22882, 2.23831, 2.25464, 2.26155, 2.2673, 2.27555, 2.28082, 2.28684, 2.29889, 2.3152, 2.33555");
            values ( \
              "-0.00518175, -0.00818684, -0.0139956, -0.0264482, -0.0306239, -0.0339575, -0.0364443, -0.0373625, -0.0336131, -0.0179373, -0.0121214, -0.00842131, -0.00477742, -0.00329196, -0.00213582, -0.000893495, -0.000324023, -0.000107376" \
            index_1 ("1.4");
            index_2 ("0.007");
            index_3 ("2.11839, 2.14173, 2.16176, 2.22281, 2.23579, 2.24783, 2.25972, 2.27158, 2.29762, 2.30869, 2.32383, 2.34259, 2.35913, 2.36202");
            values ( \
              "-0.00918096, -0.0122420, -0.0210538, -0.0513402, -0.0565257, -0.0596706, -0.0583356, -0.0493376, -0.0225367, -0.0145394, -0.00760147, -0.00322961, -0.00147464, -0.00134565" \
            index_1 ("1.4");
            index_2 ("0.014");
            index_3 ("2.1258, 2.14885, 2.16535, 2.23811, 2.25693, 2.27429, 2.29132, 2.30832, 2.36221, 2.38436, 2.40062, 2.42937, 2.46181, 2.4987");
            values ( \
              "-0.0143628, -0.0165372, -0.0253944, -0.0702879, -0.0785266, -0.0826539, -0.0820738, -0.0748284, -0.0320441, -0.0197760, -0.0135828, -0.00678620, -0.00300610, -0.00115665" \
            index_1 ("1.4");
            index_2 ("0.028");
            index_3 ("2.13414, 2.15946, 2.23803, 2.25122, 2.27761, 2.29167, 2.31164, 2.34102, 2.35807, 2.37141, 2.39809, 2.40455, 2.46556, 2.50573, 2.52503, 2.54543, 2.56289, 2.58229, 2.60073, 2.63688, 2.65705, 2.6974, 2.76418, 2.85396");
            values ( \
              "-0.0209999, -0.0232615, -0.0780083, -0.0851472, -0.0937279, -0.0954423, -0.0960131, -0.0943640, -0.0921818, -0.0896293, -0.0815030, -0.0788924, -0.0498301, -0.0332484, -0.0268704, -0.0212485, -0.0172877, -0.0136847, -0.0109111, -0.00694347, -0.00538427, -0.00319264, -0.00128846, -0.000342855" \
            reference_time : 2.625;
            index_1 ("2.1");
            index_2 ("0.0002");
            index_3 ("3.05593, 3.072, 3.08351, 3.11498, 3.12718, 3.1379, 3.15692, 3.1658, 3.17452, 3.18106, 3.19714, 3.20256, 3.20717, 3.21557, 3.239, 3.29983");
            values ( \
              "-0.000215402, -0.000282823, -0.000506893, -0.00149168, -0.00177385, -0.00196896, -0.00221902, -0.00229247, -0.00229870, -0.00210766, -0.000484763, -0.000223506, -0.000117186, -3.42061e-05, -9.21249e-06, -1.17584e-05" \
            index_1 ("2.1");
            index_2 ("0.0018");
            index_3 ("3.07175, 3.09846, 3.14866, 3.16869, 3.18062, 3.19158, 3.20199, 3.2123, 3.22003, 3.2364, 3.24428, 3.25191, 3.26063, 3.27336, 3.27426");
            values ( \
              "-0.00216397, -0.00377217, -0.0115169, -0.0143352, -0.0158128, -0.0169592, -0.0177144, -0.0172395, -0.0144817, -0.00575657, -0.00301938, -0.00150965, -0.000610087, -0.000159827, -0.000154386" \
            index_1 ("2.1");
            index_2 ("0.0035");
            index_3 ("3.07176, 3.09208, 3.10756, 3.13088, 3.18875, 3.20214, 3.21435, 3.22599, 3.2376, 3.26655, 3.27693, 3.28511, 3.29177, 3.30509, 3.32293, 3.37364");
            values ( \
              "-0.00313736, -0.00375757, -0.00627547, -0.0112880, -0.0248289, -0.0275481, -0.0296338, -0.0307124, -0.0284816, -0.00940499, -0.00503952, -0.00296402, -0.00188133, -0.000719960, -0.000259477, -5.99722e-05" \
            index_1 ("2.1");
            index_2 ("0.007");
            index_3 ("3.08023, 3.1042, 3.11095, 3.12199, 3.13688, 3.14935, 3.20776, 3.23297, 3.24736, 3.26135, 3.27528, 3.29929, 3.31204, 3.31826, 3.32656, 3.33314, 3.34024, 3.3497, 3.36849, 3.39388, 3.42487");
            values ( \
              "-0.00513490, -0.00655590, -0.00802051, -0.0108004, -0.0151655, -0.0191954, -0.0393451, -0.0469632, -0.0501345, -0.0503191, -0.0437356, -0.0240118, -0.0153973, -0.0121470, -0.00874310, -0.00662195, -0.00490587, -0.00328993, -0.00135519, -0.000411198, -5.70076e-05" \
            index_1 ("2.1");
            index_2 ("0.014");
            index_3 ("3.09097, 3.11975, 3.13007, 3.15875, 3.2428, 3.25637, 3.27615, 3.295, 3.3138, 3.31637, 3.36876, 3.39076, 3.40803, 3.43654, 3.46821, 3.50831, 3.55491");
            values ( \
              "-0.00830896, -0.0111522, -0.0144172, -0.0255251, -0.0629144, -0.0679301, -0.0735463, -0.0754574, -0.0706689, -0.0693063, -0.0315696, -0.0197671, -0.0133412, -0.00674657, -0.00306486, -0.00102667, -0.000269764" \
            index_1 ("2.1");
            index_2 ("0.028");
            index_3 ("3.10525, 3.13878, 3.24874, 3.28342, 3.31458, 3.34496, 3.37528, 3.39455, 3.51117, 3.55756, 3.5988, 3.66063, 3.72153");
            values ( \
              "-0.0148569, -0.0185491, -0.0743878, -0.0871141, -0.0923230, -0.0924396, -0.0885895, -0.0835443, -0.0331359, -0.0196132, -0.0119525, -0.00551965, -0.00270438" \
            reference_time : 5.25;
            index_1 ("4.2");
            index_2 ("0.0002");
