  3. Is there any way to convert .tf file into .tch file?
  • Subscribers 95
  • Views 17401
Anklon
Anklon over 9 years ago
I need *.tch file for creating RC corner in tsmc180 technology file. But they provide me with .tf file ?
Is there any way to convert it ?
If not, what format of file I should search for which could be used instead of *.tch file.
FYI: I tried to use .tf file instead of .tch file which is causing error. So I'm guessing  wrong format is the reason behind this.
    No, because they're for different things. A ".tf" file is a Virtuoso ASCII technology file (probably - the suffix is only convention), whereas .tch files are for the cell-level extractor (e.g. with Encounter). They would be produced by Techgen -cell (I think).
    You either need to ask TSMC for the correct file (you didn't say which tool you want it for), or get a ".ict" file which can be used as the input for Techgen.
  • Anklon
    We need it to use in INNOVOUS.
    In "project.view" file it is required to mention .tch file as far I understand. Don't know is their any other way. Thanks
    Did you contact TSMC? That's the way forward here in my opinion.
    I've moved this into the Digital Implementation forum in case anyone there can give you an alternative.
