  3. Level-shifter cells are removed after placement
  • Subscribers 95
  • Views 16861
manpmanp
manpmanp over 9 years ago
Hi there!
In my design, I intend to have a power domain containing all level-shifter cells.
The Tool for synthesis is Synopsys Design Vision (K-2015.6-SP4) and the PNR tool is Cadence Innovus (v16.13) and technology ST 28FDSOI.
The steps I have taken towards this target:
1- using a clock buffer as the level-shifter component in LevelShiftDomain.vhd
2- synthesizing the design
3- CPF file containing all necessary details, such as powerDomains and their definition, all available level-shifter cells to use (define_level_shifter_cell) and rule to use them (create_level_shifter_rule)
however after place_design, cells  from level-shifter power domain are removed.
What is your suggestion to solve this issue?
  • Andorra
    Andorra over 9 years ago
    I have the same question.
  • manpmanp
    I could solve my problem by following the steps mentioned below:
    1- The level shifters are defined in the library with a specific vddi and vddo. for HL or LH check and use the necessary (both or one) one in the CPF libraries.
    2-Define the level shifter cells with define_level_shifter_cell and use the range as input and output voltage as may be needed and later match the power domains
    3-check the create_power_net for the crossing power domains contains the required ranged which has been defined previously in define_level_shifter_cell
    4-create_level_shifter_rule and think in advance about the right combination of the defined cells, defined libraries, vddi and vddo in libraries, and finally the location of placement by setting the a correct -from and -to info in this command
    5-If using create_level_shifter_rule more than once remember to use update_level_shifter_rules -names -location to force the implementation either for each rule separately or put all similar ones in the same update command
    good luck
