  3. I/O pad pins are placed randomly (each pad_pin is not placed...
  • Subscribers 93
  • Views 1567
I/O pad pins are placed randomly (each pad_pin is not placed on the corresponding pad)
Andorra
Andorra over 9 years ago
Hi all,
in Innovus 16.2, after "init_design", the I/O pads' terminals are not placed on the corresponding pad. Does anybody have had similar problems? or any clue about this?
As you can see in the screenshot, there are 3 yellow triangles (pad's terminal). the 2 at left side are placed correctly ON THE PAD. however, the third one at the right side is placed ABOVE THE PAD.
This problem occurs after "init_design". the pads settings are the same, but some of pads' terminals are placed randomly.
