  3. POwer routing : Top level Block PG pin routing
  • Subscribers 94
  • Views 18182
remi pallas
remi pallas over 8 years ago
I'm using hierarchical methodology. I did block place and route. I generated lef abstract using : write_lef_abstract ./RESULTS/${DESIGN_NAME}_abstract.lef -stripePin -PGPinLayers {2 8} -extractBlockPGPinLayers {2 8} -cutObsMinSpacing
I'm doing power routing and especially want to connected block PG pins with STd cell power rails (row). But I cannot on every block. When doing sroute , some power rails remains open (see the picture).
When doing point to point route , it says on some pins :
**Info: Selected object: "-net {VDD M2 (361.58 242.084)}".
**Info: Selected object: "-pin {-1 VDD (361.444 242.084)}".
**Info: Calling routePointToPoint -routeLayer M2:M2 -width 0.208 -spacing 2.0 -routeStyle manhattan -net {VDD M2 (361.58 242.084)} -pin {-1 VDD (361.444 242.084)}
routePointToPoint ...
>>> Begin point to point routing for 'VDD'
**WARN: (IMPPPR-445): OPEN in 'VDD' (234.704 242.000)=>(361.850 242.000) because of too much congestion or blockages.
Net VDD failed to route.
That's weird because I suppressed all my block routing blockages and  I'm before routing stage.
Maybe there is a congestion problem related to my block's pin ?
Rémi
  • remi pallas
    ALways with my problem of open on my block's PG pins. Sroute cannot afford to route all the Vdd/gnd power rails. You can see in the picture below the white crosses at the boundary of some blocks.
    I found that the problem is related to the way you floorplan your design. I mean block location (I did relative floorplanning) and row density. It seems that in my case increasing row density betters sroute results.
    SO my questions are , in the case of bottom-down hirarchical methodology , how do you floorplan? How do you power route (both top level and block side)?. Is there any rule of thumb?
    Rémi
  • remi pallas
    remi pallas over 8 years ago in reply to remi pallas
    Right now , I cannot find the cause of my problem (Other collegues got that problem too). So I will use an ugly solution 1234
    -draw ring inside blocks to connect VDD/GND rails .
    -draw  VDD/GND ring around blocks at top level
    -connect rings together using vertical stripes (see the picture)
    Rémi
