  3. Encounter via placement rules
  • Subscribers 93
  • Views 5425
masserg
masserg over 8 years ago
Good day.
I just studdy place and route procedure by Encounter and got a problem.
My foundry prohibits to locate via on thin oxide (minimal space 0.1u), but I cannot handle it by Encounter.
By IC Craftsman I can do it by rule specify:
rule IC (inter_layer_clearance 0.1 (layer_pair VIA12 FieldOxide))
In Encounter I didn't find such a solution.
In LEF file, generated by Abstract Generator, I can put VIA12 layer blockage like
ThinOxide = DIFF AND POLY1
VIA12 BLOCKAGE = VIA12 OR ThinOxide
But it works like standard VIA12 blokage with minimal space for this layer 0.6u, but I need VIA12 to VIA12 space 0.6u and VIA12 to ThinOxide 0.1u.
I didn't find Layer to Layer space rules in LEF file description.
BTW, Abstract Generator always occupies 100% of CPU even when it does nothing (just starts). What's wrong with it (version 5.1 on Linux)?
Thank you and best regards.
