  3. Restrict innovus tool in placing VIABAR
  • Subscribers 94
  • Views 16626
manpmanp
manpmanp over 8 years ago
Hi
I am going through the digital flow using the innovus digital implementation flow.
may anyone help me how to restrict the tool not to put VIABAR in its routing stages?
BR
MANP
  • Kari
    Kari over 8 years ago
    Can you explain more what you mean by VIABAR? Do you mean rectangular vias, or a layer called VIABAR?
  • manpmanp
    manpmanp over 8 years ago in reply to Kari
    Hi Kari
    Thanks for your reply. I am not sure exactly in what situation it is called VIABAR. Anyways, after finishing the PnR flow in Innovus, I import the the .gdsII and netlist file to virtuoso for checking the LVS and DRC.
    I think for 'single-cut vias' (a large big via), the DRC gives an error of VIABAR and I have to replace that VIABAR with two or more distanced smaller vias.
    In fact, I want to limit the Innovus tool in inserting those big troublesome vias.
  • Kari
    Kari over 8 years ago in reply to manpmanp
    Sounds like you have a situation where there is wider metal that requires a double-cut (or more) via instead of a single-cut. There are usually rules in the LEF file that say what metal widths need double-cut vias, as well as defined double-cut vias for the router to use. Make sure you have these things in your tech LEF.
