  3. Blackbox pin after partition
  • Subscribers 94
  • Views 16580
gdellaca
gdellaca over 8 years ago
I have a problem with pin assignment using Innovus 16.22
I define part of my circuit as a blackbox and I assign its pins with the editPin command. The pins are fixed because I use the -fixedPin 1 option
When I commit the partition with the partition command, some of them are moved to random positions using also a layer wich is not reserved for the blackbox.
Please any suggestion?
Regards
Giulio
  • gdellaca
    I can answer it myself. Since I had many input pins connected to constant values, and some of them were moved during partition,  I've tried to add the tie cells in the synthesis. This solved the problem. Still I don't understand why, but it worked.
