  3. Dangling wires/extra net length using -sroute command
  • Subscribers 94
  • Views 7350
kash022
kash022 over 8 years ago
I am using multiple power domains in my design and while doing the routing of power structures (using the -sroute command), I see that the VDD_CORE1 wire (in my case) always extends by a small margin beyond the power domain. Before running the sroute command, I use the modifyPowerDomainAttr commad to adjust the size of the power domain so that it sits exactly on top of the power rail I want to route. And then I use the sroute command.
But I keep getting this "dangling" wires which is leading to further DRC errors; also sometimes for the global PWR rails, the routing is incomplete leaving the nets unconnected.
Please assist me in this.  I am attaching a screenshot of the issue and the command I am using.
modifyPowerDomainAttr PD_1 -box 188 238 262 312 -minGaps {4 4 4 4}   // adjustPower domain to accommodate the VDD_CORE1 rail exactly
sroute -connect { blockPin padPin padRing corePin floatingStripe } -layerChangeRange { M1(1) LB(9) } -blockPinTarget { nearestTarget } -corePinTarget { firstAfterRowEnd }  -allowJogging 1 -powerDomains { PD_1 } -crossoverViaLayerRange { M1(1) LB(9) } -nets { GND } -allowLayerChange 1 -targetViaLayerRange { M1(1) LB(9) }
modifyPowerDomainAttr PD_1 -box 200 250 250 300 -minGaps {4 4 4 4}  // re-adjust back to original
Kashif
  • Kari
    Kari over 8 years ago
    this seems strange - are the vertical stripes on grid?
  • kash022
    kash022 over 8 years ago in reply to Kari
    It's fixed....I had to decrease using  the modifyPowerDomanAttr the length by about 0.12 um....so instead of say, 30 it fixed to 29.844 say... Thanks!!
