  3. Encounter's "common timing library"
  • Subscribers 95
  • Views 2121
mwb1
mwb1 over 8 years ago
From all the documentation that I see, it looks like "common timing library" in encounter's "import design" menu should point to the typical case library. Similarly to how the "max" and "min" libraries point to the worst and best case libraries.
However, when I look at the log, it says that its overwriting the libraries. See below.
Reading max timing library <my_wc_timing_lib>
................etc
Reading min timing library <my_bc_timing_lib>
................etc
Reading max timing library <my_tc_timing_lib>
................etc
Reading min timing library <my_tc_timing_lib>
................etc
Those last two messages seem to indicate the reading in of the common-timing library is over-writing my max and min timing libraries. Is this correct? Is this what I should see?
Matt
  • Kari
    Kari over 8 years ago
    what version are you using? the libraries should be set up using a MMMC file so that you can have as many analysis views as your design requires...
  • kash022
    kash022 over 8 years ago
    yes..this happens as your MMMC file overwrites it...so set up individual views for each instant...something like <QRC/Timting>_MAX_TYP $LIB_PATH and if you have set_analysis_view enabled or update_delay_corner make sure it references each library...so for 3 cases you should have 3 views on delay/power etc... I would recommend something like
    create_library_set -name library_typ_device  -timing [list $your_libraries_here]
    do this for max and min and other corners accordingly
